Pic of my PCV catch can
Old Sep 11, 2002 | 07:21 PM
Reckless's Avatar
Super Moderator
Default Pic of my PCV catch can
As promised a while back...it's a Moroso Radiator overflow can. Added an extra fitting on the side and ran some black auto store hoses and a 90-degree PCV right before the intake.
<img src="http://www.turbo-ws6.com/catchcan.jpg" alt=" - " />
Old Sep 11, 2002 | 07:25 PM
Reckless's Avatar
Super Moderator
Default Re: Pic of my PCV catch can
Here's a wide-angle view <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<img src="http://www.turbo-ws6.com/bay9.jpg" alt=" - " />
Todd
Old Sep 11, 2002 | 07:28 PM
Dope's Avatar
Hey Reckless,
Your AC compressor looks a lot different than mine <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Dope <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 11, 2002 | 08:28 PM
BigRay77's Avatar
what is the point in messing with the pcv???
Old Sep 11, 2002 | 08:30 PM
99Z28RS's Avatar
OK, call me stupid, but i actually dont really know what the pcv does and why did you make a catch can for it?? and is that a MAFT by your lid?
Old Sep 11, 2002 | 09:38 PM
LS1x2's Avatar
Formerly 4mulaJoe
How well is it working for you?
Old Sep 12, 2002 | 07:18 AM
Reckless's Avatar
Super Moderator
The reason for this mod is to eliminate or decrease oil consumption by the LS1 engine. They are notorious for this. By employing a catch can in-line, the oil get deposited in the can, rather than sucked into the intake.
99Z28RS...not a MAFT, although it looks like one, that's the 2-step made by Matt Harlan. The leads go to the coil pack harnesses.
Todd
<small>[ September 12, 2002, 07:18 AM: Message edited by: Reckless ]</small>
Old Sep 12, 2002 | 01:23 PM
Reckless's Avatar
Super Moderator
Very thick plastic...one quart, $25.99 from Jegs:
<img src="http://www.jegs.com/photos/71063657.jpg" alt=" - " />
Todd
Old Sep 12, 2002 | 02:18 PM
nthnwbr's Avatar
Thanks, Todd! How is that fitting attached? Is it threaded into the plastic, or made as part of the tank? Is there a metal insert with threads there? Sorry for all the ????'s but I really like that set-up you have.
Old Sep 12, 2002 | 02:36 PM
Reckless's Avatar
Super Moderator
The fitting supplied with the can screws in (I think it is threaded). There is also a small breather hole in the top which I plugged with a small screw and some rtv. For the fitting on the side, I just drilled the appropriate sized hole and screwed the fitting in. Used some black rtv around the base of both fittings, then painted everything flat black.
Bought a 90-degree PCV valve from Autozone and put it inline. Had to use a couple different hose sizes to piece everything together.
The hose from the driver's valve cover crosses over to the passenger side. I used a 3/8" tee to join the hoses at the passenger cover, and then feed down to the can. I used a small K&N breather to provide fresh air on the front fitting of the passenger side cover. I plugged the fresh air outlet on the throttle body.
Guess I should have explained all that up front <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Todd
Old Sep 12, 2002 | 02:38 PM
Reckless's Avatar
Super Moderator
One more thing, the clamp holding the can is from Home Depot. Came on a 3-inch pvc coupling in the plumbng section. I used an aluminum pop-rivet to secure it to the strut tower, then slid the can in and tightened it down.
Todd
Old Sep 13, 2002 | 12:37 AM
nthnwbr's Avatar
What's the capacity of that tank? Is it aluminum or plastic?
