Kooks Headers Rusting????
Old Apr 16, 2006 | 12:58 AM
Hooper's Avatar
Default Kooks Headers Rusting????
I bought a set of Kooks stainless headers new back in May '04. I always winter store the car and try not to drive it in the rain too much. This spring when I took it out of winter storage, I noticed a lot of surface rust on my headers. Is this common? I thought stainless steel was rust-free. Is there anything I can do? Any input is appreciated.
Old Apr 16, 2006 | 01:12 AM
Grimes's Avatar
call them up, and I'm sure they will help you out - ss should not rust.
Old Apr 16, 2006 | 01:14 AM
JustAnIlluzion's Avatar
depends what grade of ss it is
Old Apr 16, 2006 | 04:29 AM
CAT3's Avatar
Restricted User
You may get a slight bit of surface oxidation, but a simple cleaning up will take care of it. Most coated headers have cleaning instructions with them, I was surprised to see the Kooks didnt, even though mine arent coated I would expect to clean them up. Some have actually polished them prior to install. GL
Charlie
Old Apr 17, 2006 | 01:59 AM
Hooper's Avatar
If I were to take them off, what would be the best method to clean them? And would it make sense to have them coated now? Thanks.
Old Apr 17, 2006 | 02:58 AM
TheBlurLS1's Avatar
That's what she said...
I would clean them with some carb cleaner and maby a wire brush, then spray it again and wipe it off with a rag. No point in having them coated, I'd like people to see STAINLESS when I popped my hood, not ceramic.
Old Apr 17, 2006 | 07:07 AM
Zger's Avatar
I had a set of headers glass beaded and they came out like new. All the surface rust came right off. They weren't stainless, so I just painted them.
Old Apr 17, 2006 | 11:08 AM
Redneck Z's Avatar
Do the QTP's and Kooks use the same grade of SS? I see threads where the kooks rust, but have never heard of this happening to the QTP's.
Old Apr 17, 2006 | 01:32 PM
daryl2cb@yahoo.com's Avatar
I think they have a finish warranty on them, or they should for 800+ dollars. contact them and let us know what they say.
Old Apr 17, 2006 | 01:57 PM
slpss9723's Avatar
I have QTPs and they did this after just a couple months of use......rust all on the bottom and sides of the both collectors. They're not rusting through or anything but there is definitely rust on them. I don't know about what grade Kooks uses, but QTP uses 304 stainless which is the good stuff.......
Old Apr 17, 2006 | 02:23 PM
conan's Avatar
The kooks are 304 aswell.
