Hooker LT install ??
Old Sep 24, 2002 | 08:40 PM
98_B4C's Avatar
Default Hooker LT install ??
Installing set of Hooker lt's and y-pipe and have a couple of questions. The rear header tube on the passenger side is very close to the heater box maybe 1/8 inch clearance. Also on the drivers side the header collector seems to be angled up toward the floor and the little short y-pipe extention is very close to the floor. Looks as if the header needs to be pulled down to get more clearance so it won't bang. Anyone else have these problems.
Old Sep 24, 2002 | 10:31 PM
John02SS's Avatar
Default Re: Hooker LT install ??
On the heater box mines has about 1/2 in, but a friend of mine only had about an 1/8th. I put some heat reflective tape on it just to be safe. My Driver side header is angled up, but the y pipe fits great. I had to pull the header down with a small pry bar to get the short piece of y pipe on, but it fits great after it is on. I have no banging, but I didn't have to adjust the pipes some. Good luck.
John
Old Sep 24, 2002 | 11:11 PM
98_B4C's Avatar
Thanks John02SS
That's what I've planned on doing for each side. Just wanted to see if anyone else's Hooker Lt's had same problem.
Old Sep 26, 2002 | 07:05 AM
Fahad's Avatar
Hi ,
After weeks i will install my Hooker LT with Ypip , when i finish from install LT , I told you <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Fahad ..
