Does anyone make a 170 degree thermostat?
Old Apr 16, 2006 | 12:06 PM
Mike94ZLT1's Avatar
Default Does anyone make a 170 degree thermostat?
I'm looking for a 170-180 degree thermostat for my C5. Isn't the stock one like 194?
Old Apr 16, 2006 | 01:13 PM
Strahley's Avatar
I think you can get a 160 or a 180. Why not just go with the 160?
Old Apr 16, 2006 | 02:02 PM
JBIRD02's Avatar
yes, Vinci High Performance has a 170 degree t-stat
check the sponsor list ---------->
Old Apr 16, 2006 | 03:13 PM
GR33N GoblinM6's Avatar
stock is 187* at least thats what the guys at GM told me..
Old Apr 16, 2006 | 04:21 PM
Mike94ZLT1's Avatar
Holy hell... the 170 degree thermostat at Vinci is SEVENTY DOLLARS...
Old Apr 16, 2006 | 06:07 PM
jimmyblue's Avatar
Moderator
The "160" Hypertech I have, has a natural pivot about
175F.
You probably would do better to just set the fans sane,
and leave the thermostat alone. If you are short on
real cooling capacity then upgrade fans and radiator.
The thermostat is not the reason you overheat, barring
failure of some sort. Thermostat temp sets the minimum
running coolant temp and that is all. Airflow, coolant
flow, waste heat produced and heat exchanger efficiency
set the upper end. If you have an upper end problem,
look to those. Starting with airflow (fans) as the one
that is both factory-stupid, and free (if you have the
tools).
Old Apr 16, 2006 | 06:08 PM
mrr23's Avatar
it's the entire housing. not just the t-stat itself. the housing is modifed as well with a bypass.
Old Apr 16, 2006 | 07:27 PM
Strahley's Avatar
I got my LS1 160 degree thermo (thermostat, housing, and a new gasket) for 20 bucks from O Reilly's
Old Jul 11, 2006 | 08:07 PM
99vertA4's Avatar
Code:
whats the brand and part number? thanks
Old Jul 11, 2006 | 10:44 PM
Blk02Ls1A4's Avatar
My stock thermostat had 100* C imprinted on it, which would make for one hot engine. I went with a 180*, starts opeining at 180, completely open at 200*.
Old Jul 11, 2006 | 10:46 PM
radz's Avatar
True and its a very nice piece, much nicer than the "motor-rad" hypertech/SLP
Old Jul 12, 2006 | 09:33 AM
TheBlurLS1's Avatar
That's what she said...
Originally Posted by 99vertA4
Code:
WTF?
Old Jul 12, 2006 | 09:50 AM
2xLS1's Avatar
Code:
Murray Plus #37960. It is identical to the Hypertech made my Moto Rad.
