BG ram air mod
Old Oct 6, 2002 | 02:01 PM
Fierce-LS1's Avatar
Default BG ram air mod
Heard about this mod. Does anyone have this, if so what gains were seen ? Where can I get one ?
thanks
Old Oct 6, 2002 | 03:40 PM
Fierce-LS1's Avatar
Default Re: BG ram air mod
ttt
Old Oct 6, 2002 | 03:50 PM
miner_49's Avatar
If you do a search on BGRAM you'll find alot of posts already about it. Its not going to help you on a dyno, but it does help some when driving at high speed.
I bought mine from http://www.ls1speed.com/catagory.cfm?catagory=induction (a forum sponser).
<small>[ October 06, 2002, 03:52 PM: Message edited by: miner_49 ]</small>
Old Oct 6, 2002 | 04:11 PM
Fenris Ulf's Avatar
This is definately a worthwhile mod, very noticable at highway speeds.
Old Oct 7, 2002 | 01:34 PM
Racehead's Avatar
Like he said, it is easily noticable at high speeds. It won't make any differance on a drag strip, at least very little anyway, but I was able to go 165 mph for probably 50 miles, with an inch of pedal left on a 340 rwhp car. I sure would like to know my rwhp at 165 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 7, 2002 | 07:04 PM
Fenris Ulf's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Racehead:
<strong>Like he said, it is easily noticable at high speeds. It won't make any differance on a drag strip, at least very little anyway, but I was able to go 165 mph for probably 50 miles, with an inch of pedal left on a 340 rwhp car. I sure would like to know my rwhp at 165 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually it will help on the drag strip. Should be very similar gains to the FTRA.
Old Oct 7, 2002 | 08:01 PM
DONAIMIAN's Avatar
165 for 50 miles, where did you find enough road to do that. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Oct 8, 2002 | 10:12 AM
tempting99's Avatar
Isnt this the same thing as just removing your baffels that are in your nose??
Old Oct 8, 2002 | 11:00 AM
02 SOM WS6's Avatar
Go to Brian Green ram air mod home page.
Everyone that I have seen post about this mod says it is a very well made piece. Check it out.
Les
Old Oct 8, 2002 | 08:56 PM
jimmypop13's Avatar
I noticed a huge gain everywhere. Took me all morning with my dad helping to get the whole kit put in but it was deffinately worth it. I'd recommend it to anyone with a stock WS6 hood. I noticed a whole lot down low too, I guess just because of the colder air. The only problem I'm having is my gasket it breakin off in pieces everywhere and I've always made sure to put Pam on it every now and then too. Must be the hot Texas air <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Chris
Old Oct 8, 2002 | 09:01 PM
miner_49's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Isnt this the same thing as just removing your baffels that are in your nose??</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No. These baffels are removed, but that is only the beginning. You install some plastic panels so the incoming air is funneled directly into the airbox. The airbox is also sealed to the hood (removes that 1 inch gap where warmer engine air can enter. This allows the airbox to slightly pressurize when driving at high speed.
Because you are using the WS6 hood, unlike the FTRA, the air has a straight path into the airbox (doesn't have to change direction) and doesn't block part of the radiator (causing the car to run hotter).
<small>[ October 08, 2002, 09:10 PM: Message edited by: miner_49 ]</small>
Old Oct 8, 2002 | 09:07 PM
miner_49's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">The only problem I'm having is my gasket it breakin off in pieces everywhere and I've always made sure to put Pam on it every now and then too. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Did you filed down that sharp edge like the instructions state? You do know that PAM has some alcohol listed in the incrediants unlike standard vegetable oil;which is what is recommended. Alcohol tends to break down rubber over time. I don't know if this is your problem as there can't be very much, but it is something to consider.
<small>[ October 08, 2002, 09:09 PM: Message edited by: miner_49 ]</small>
Old Oct 9, 2002 | 09:30 AM
sweetTA's Avatar
I ordered mine yesterday, we'll see how it does <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 9, 2002 | 10:05 PM
ND4SPD's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jimmypop13:
<strong>I The only problem I'm having is my gasket it breakin off in pieces everywhere and I've always made sure to put Pam on it every now and then too. Must be the hot Texas air <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's why I bought the TEF's & grommets but made a better hood to airbox seal. Never comes off, requires no holes or drilling and have never used PAM. You can also use it with or without removing factory baffle or baffles. You can see it in my album through link in sig. if interested.
<small>[ October 09, 2002, 10:07 PM: Message edited by: ND4SPD ]</small>
Old Oct 9, 2002 | 11:07 PM
Mike Hoffpauir's Avatar
nd4spd nice car!
I really like your keyhole covers
http://community.webshots.com/photo/...48514084NjnzkX
Where did you get them and are they available for camaro's?
Old Oct 10, 2002 | 03:30 AM
Smoke_Ford's Avatar
I cut the bottom of my airbox out, and I sawed off my EGR valve, I noticed a lot for a free mod from that.
Old Oct 10, 2002 | 04:45 AM
akaceril's Avatar
is there something like this for the SS??
Old Oct 10, 2002 | 05:21 PM
J'sRamAir's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mike Hoffpauir:
<strong>nd4spd nice car!
Where did you get them and are they available for camaro's?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah, where did you get them from? I hope they come in solid black though. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 12, 2002 | 08:46 PM
Bad30th's Avatar
Definately worth it, two thumbs up !
Bad30th
