De-screened MAF vs Ported MAF
<strong>I know the ported MAF will lean out the engine (I have a ported MAF and a stock MAF),but a De-screened MAF with the divider still in place does it lean out the engine also or does it keep it close to stock MAF settings and does it flow like a ported MAF?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I de-screened my stock maf and left divider in and it still leaned out my car BAD, like 14.1+ at lowest. I ended up going over to Ls1speed.com and buying a LS6/Z06 MAF Conversion for like $150 that comes with an 85mm MAF and harness. It richened me back up and didn't cause any bad side effects. No KR and I run at 26 degrees advanced under WOT.
If I had to do it again I'd just buy the one from ls1speed.com first and if I had problems I'd atleast have a stock untouched MAF to go back to. Now if I have problems with my 85mm I'm gonna have to go out and buy a stock MAF <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
<small>[ October 08, 2002, 11:50 AM: Message edited by: CamaroSS_2002 ]</small>
<strong>Actually there is no need for the screen on 98-up F-bodies and 97-up vettes, that is why GM took it out for 02 Z06's b/c they realized this. Its in some issue of GMHTP, I can't recall which one though. The screen is made for vehicles such as 94-97 LT-1 F-bodies and GM Trucks, b/c those vehicles have bends in the intake path such as the air enters the air box, bends up and to the left and then to the right into the t.b. well LS1 Vettes and F-bodies have straight intake paths, air enters and goes straight to the t.b....its in GMHTP, so it doesn't hurt it at all, such as lean it out or anything. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Z Yall Later</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">All this is true, however you forgot to mention that the GM engineers also did alot of recalibrating (A4 line pressure etc...)to offset any lean condition caused by descreening the MAF on the ZO6. Our f-body's have not been calibrated for this and therefore will not perform in the same manner. I took off my Whisper ported maf ends and retained my stock screened ends.
I did this mod about 3000 miles ago.There was a big difference in throttle response.
I got on it from a dead stop,she was burning rubber for about ten feet and then took off like bat out of he**,even got second gear rubber with the stock rearend gears,broke the rear exhaust hanger.
I don't know if I should put the screen back in or not,I don't want to cause any problems for my new car. Not sure what to do.
<strong>No pinging whatsoever. I hope I don't cause a problem for the A4 trans.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">taking the screen out really isnt do do squat! You're 100% fine with the screen out. Its the totally ported ends that cause lean issues. With my screen in or out I got the same 02's numbers on atap... with it ported they dropped from .94 down to .88-.90
also a descreened end really isnt gonna give ya but maybe .05-to 1hp is any. Its just the i did a mod so it must be quicker feeling.
<strong>I think Colonel meant to say he took the screen out of the MAF's on his SS and Z not the TB. If not please excuse me.
Jim</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Oops! Uhm yes, MAFs. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
