** The best poly motor mount write up ever written **
Anyone want to buy a set of New in the box prothane motor mounts?? Im SERIOUSLY thinking about just doing solids instead.
what is this im reading about shaving the tips of the long bolts that go through the mounts? how much of a needle nose to you guys give it?
i guess this will be a bit easier while installing headers. damn i kinda wanna put a cam in while the motor is practically out. how hard would it be to but an off the shelf thunder cam in?
im purchasing my poly mounts as we speak. i guess i should stock up on some beer for this upcoming BS
I also installed the driver side long bolt backwards. Inserting it from the rear of the engine compartment and having the nut on the front. This way you have next to nothing in the way so you can use a hammer to pound that sucker home. Hope this helps. Good luck.
through bolt 70 lb ft
pedastal bolts 43lb ft
If you just loosen the through bolt and take out the mount to block and pedastal to k-member bolts it comes out as one piece. That way you don't have to do anything with the a/c compressor or alternator.
