Maf ???
Old Apr 22, 2006 | 09:31 PM
1999 SS's Avatar
Default Maf ???
is their ANY benifit of going with a granatelli maf?
i know a couple of ecm tuners and they have nothing good to say about them.
Old Apr 22, 2006 | 09:34 PM
SSilverSSurfer's Avatar
i would do a z06 maf...is it the same? i had a slp maf and my tuner had nothing but problems
Old Apr 22, 2006 | 10:52 PM
blkZ28spt's Avatar
What mods do you have? Plan to have?
Personally I wouldn't touch the MAF. Maybe descreen it, but that's all.
Old Apr 22, 2006 | 10:54 PM
DrkPhx's Avatar
DO NOT use it on a stock or bolt on car. It will cause problems. Use the stock one.
Old Apr 23, 2006 | 01:13 AM
Lithium's Avatar
SSU's Drunk Typing Whore
Stick with the stocker unless you are planning on going 85mm 85mm 3x4 90mm 90mm
Old Apr 23, 2006 | 02:07 AM
TheBlurLS1's Avatar
That's what she said...
Old Apr 23, 2006 | 03:05 PM
1999 SS's Avatar
i learned my lesson long ago with the granatelli. i was curious if everybody had the same experiense as me.
Old Apr 27, 2006 | 07:29 PM
lsx24's Avatar
Do you have access to a tuner? If so, what kind? (i.e., hypertech doesn't count...).
Old Apr 27, 2006 | 07:31 PM
natronathon's Avatar
**** i turned mine off! no maf!
Old Apr 27, 2006 | 07:35 PM
ls1mojo's Avatar
I ditched my computer because it has too much resistance.
Old Apr 27, 2006 | 07:55 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Dont mess with it. not worth the money/time.
Old Apr 28, 2006 | 01:01 AM
GIGAPUNK's Avatar
I'm building up an '03 vette longblock with a 90mm tb. I already bid on an SLP MAF on Ebay, but now I keep hearing about people having problems with the SLP MAF. I plan on having a completely custom tune when the engine is complete. Do the problems with the SLP MAF arrise from a the need to retune after the mod, or are people actually having problems with the accuracy of the SLP units' measurements. Does the SLP have a devider down the center like stock?
Old Apr 28, 2006 | 09:27 AM
lsx24's Avatar
Here is why I ask because a larger MAF acts much like a ported TB. It increases throttle response, and has the effect of allowing for greater hp by means of parasitic vacuum. Just like in every other MAF application.
In other words, we're talking about standard hot rod techniques people.
To elaborate, although a 75 mm MAF is not a huge restriction, it isn't very free flowing either, exactly like a stock tb. Once you increase the flow of the MAF, as long as you have a lid that can support it, the motor will be able to pull more air with less resistance, just like any other ported component in the intake track.
Now, it doesn't come without it's disadvantages. It's expensive, in a cost/performance ratio, for one (somewhat like a ported or aftermarket intake). Second, it won't work perfectly without tuning. That is crucial to MAF success in any application, ls1 MAF is no exception. Again, these are characteristics that you have to weight against your entire combo to see if a MAF is really right for you.
Old Apr 28, 2006 | 09:31 AM
lsx24's Avatar
In addition, stick with the factory ls6 MAF (which is actually manufactured by Delphi). They are most consistant for a reason.
Old Apr 28, 2006 | 09:42 AM
Badls6SS's Avatar
the slp one is a stock gm 85mm maf with a resistor soldered in between the bars. IF you get it for a good price just unsoldered the res. and you will be good to go. But you are going to need your pcm retuned
Old Apr 28, 2006 | 06:56 PM
1999 SS's Avatar
whats the resistor all about?
Old Apr 28, 2006 | 10:36 PM
GIGAPUNK's Avatar
Probably Tweaks The Out-put Of The Intake Air Temperature Sensor So That The Ecu Thinks The The Air Is Colder Than It Actually Is To Allow More Timing Advance, Hence Extra Hp. Talk About Some Stone Age Tuning. Why Don't We All Just Tweak Our Fuel Pressure Regulator While We're At It?
Old Apr 28, 2006 | 10:44 PM
carrsls1_camaro's Avatar
What size is the LS6 MAF and will it hook up to a stock wireing harness? I see you have a red hose on it is that needed for the install? TIA
Old Apr 29, 2006 | 11:36 AM
lsx24's Avatar
I went with the ls6 one from PACE, where it's all from: the MAF, the pig tail connector harness (including IAT sensor built-in), and the transition rubber component.
I like the characteristic you can purchase all that is required from just one place, not to mention a place that not only is familiar with the sort of component replacement but also have a history of great success.
Old Apr 29, 2006 | 11:54 AM
Badls6SS's Avatar
The slp harness only has 3 wires and is for the maf signal the MAF its self has 5 terminals 2 are for the IAT which is not used
