EGR removal
Old Oct 17, 2002 | 04:27 PM
EvilSS's Avatar
Default EGR removal
I need help with the EGR removal on my 2000 SS.
Recently I removed the AIR and EGR system. I used simple metal block off plates to close the old holes. The problem is with the EGR connection at the intake manifold . The mount only uses one bolt and when I tighten it, the plate lifts up slightly on the opposite side. This allows for a hair line opening for air. Naturally, the PCM tries to adjust things and my idle RPM cycles between 400 and 2100 in 10 second intervals.
I use LS1_Edit so the sensors are disabled and there is no MIL (SES).
To keep the engine neat, I would like to still use a simple block off plate instead of cutting the old EGR tube. I do not plan to get the LS6 intake real soon-probably a year away. Until then, does anyopne have any suggestions/experience in this mod? Maybe a better block off plate is out there somewhere?
Thanks!
Old Oct 17, 2002 | 04:30 PM
sited12's Avatar
Default Re: EGR removal
High temp silicone gasket. I used that and it pretty much is just chaulk.
Old Oct 17, 2002 | 07:56 PM
NC Guy's Avatar
Amen,
High Temp 100% silicone gasket will fill small gaps. Allow it to cure for 24 hours and don't use too much as it can clog critical oil passages.
Old Oct 17, 2002 | 08:01 PM
J'sRamAir's Avatar
You could use a freeze plug or an expandable rubber plug instead of a block off plate.
Old Oct 19, 2002 | 02:18 PM
BIG PD's Avatar
use the expandable plug. you can get them at pep boys for like 2 bucks. stick it in the hole and turn the bolt...sucker isn't gonna move. i've had mine in for about 3 months now. not sure what size you need though.
Old Oct 19, 2002 | 09:15 PM
Sickboy's Avatar
JUST BLOCKED MINE OFF AS WELL. YOU NEED A
"1 3/8" FREEZE PLUG OR BETTER A RUBBER EXPANDABLE PLUG. $2.00 AT THE PARTS STORE. WORKS GREAT
Old Oct 20, 2002 | 07:25 AM
EvilSS's Avatar
The freeze plug worked great guys! Thanks. <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
I got a 1 1/4" from AutoZone for $2.99. Car runs smooth and predictable now.
Now back to some more LS1_Editing!
