Why do we have such crappy intakes to choose from...........
I'm talking big cube engines. FAST 90, LS7, Holley, Weiand choke a big engine still. The Harrop is the only one thats worth a damn. Whats the big deal in making a good flowing intake?
Originally Posted by GR33N GoblinM6
what kind of cubes are you pushing? There are plenty of people that will make a sheet metal intake if your engine needs it.
The sheetmetal intakes have there problems though, with the low end torque and something to do with being bad for daily driving at slower speeds and lower rpm's.
Can a shop build one that flows a LOT more than the 90mm stuff yet still operate and work just like they do?
Yeah im sure designing a big cube intake is soooo easy, they are just being lazy. lol
Theres probably not nearly enough market for one to justify spending so much money in developement.
Originally Posted by chriswtx
Here is something new. Looks promising...
http://www.professional-products.com...oldsLS1LS2.php
Originally Posted by tc3
Originally Posted by theblur98ss
buy a harrop and let us know how it does.
victor jr. intake, Aaron's aluminum elbow, and a 90mm or accufab 105mm t-body. that should feed your 436. i do have a friend that is running a Futral built 434 and runs a fast 90/90 setup.
Does this Victor Jr. set up with the 105mm Accufab TB and elbow still use fuel injection?
Originally Posted by Quickin
It's just wierd that the Harrop intake uses eight 58mm TB's, one for each cylinder. Thats equal to a 464mm TB, but feeds each cylinder equally and doesn't starve the rear cylinders like the FAST, Holley, Wieand, LS1/6/7 intakes do. Just seems someone would have designed something better.
2. Yes, the vic jr can be purchased set up for fuel injection. it comes drilled for individual port injectors. The elbow and TB act just like a OEM TB on the car now.
Originally Posted by Fireball
1. 8 58mm TBs does not equal a single 464 mm tb. If you look at an area basis, A 164mm TB would have the same area BUT you have significantly less boundary layer (air does not flow right against a wall) 8 85mm tbs has 1458 mm of wall (for any given cross section) where a 164mm TB only has 515 mm. Thus it shows that an "equivalent" TB is << 164 mm
It seems the size of the elbows inlet is the limiting factor in airflow.
Idon't see prices on the sites for this V Jr/elbow set-up....do you know what the entire set-up costs off hand?
Do you think, or is there any proven tests that show the V Jr./elbow set-up will flow like (or outflow) a Harrop? Or do you think the Harrop is still better?
Intake + fuel rails are ~400.00
Elbow is 200-250
I never said outflow, didn't even compare them, but your approach in comparing them was wrong...thats all I was point out.
Elbow is 200-250
Elbow is 200-250
Thats pretty cheap if it'll "at least" outflow the FAST 90 or LS7 intakes.
