Header leak
Old May 8, 2006 | 01:51 PM
TheBlurLS1's Avatar
That's what she said...
Might want to get ahold of Kooks since SUX2BU said his came with them. If you can't get ahold of them directly, call one of our sponsers and see if they can help you get a set. Calling the place you bought the headers from would help too.
Old May 8, 2006 | 06:45 PM
97MysticZ's Avatar
What's a Sticky?
Originally Posted by ShevrolayZ28
None of the Autozones I called had Percy's. $35?...that would be Percy's reusable aluminum header gaskets. They also make a carbon header gasket for around $14, and from the sound of the manufacturer's discription the carbon gasket might be the better of the two for sealing a leaky situation.
Has anyone on here used Percy's carbon header gaskets?
Well the Autozones around my area have Percy's. I wouldn't really waste my time with the carbon gaskets. The aluminum ones are more expensive but they are awesome. They are double thick gaskets, so if they leak, you have a major problem. And to boot, they are reuseable.
Old May 8, 2006 | 06:54 PM
Malko's Avatar
Not to hijack, but I just replaced my gaskets back to OEM with pacesetter headers (I've been thru felpro and mr gasket) and i still have the most annoying hissing noise ever. I hate taking my headers off all the time...
Just how thick and how nice are these Percys? Will they stand up to n2o abuse?
Old May 8, 2006 | 06:59 PM
emerica4601's Avatar
From: king of prussia, pa (home) and williamsport, pa (school)
copper gaskets =
Old May 8, 2006 | 08:33 PM
TheBlurLS1's Avatar
You can simply unbolt the header, slide the gasket out, and slide a new one in. Most people on here beat the **** out of them even with the factory gaskets.
Old May 8, 2006 | 11:48 PM
Malko's Avatar
That's right, but it's a pain. especially getting the holes too line up again properly - a downside to having all your stuff welded on (think weight...)
Old May 9, 2006 | 12:43 AM
TheBlurLS1's Avatar
If you just do one side at a time, it will stay lined up pretty well. Mine did at least....
Old May 9, 2006 | 09:59 AM
ShevrolayZ28's Avatar
lol @ the phone book. A chunk of 4x4 works well too.
I ordered a set of Percy's carbon gaskets ($15 from Summit). They should arrive tomorrow. Here's the manufacturer's description of the part:
Percy’s High Performance, Inc. introduces XX Carbon Gaskets made of Percy's proprietary 100% carbon material. These gaskets can withstand long term direct exposure to over 2000° farenhight. They offer superior sealing ability on the worst flange surfaces and are perfect for nitrous, turbo, and blower motors.
XX Carbon Gaskets are available for every popular application and can also be custom cut or easily port matched.
