best way to remove power steering pulley?
Old Apr 28, 2006 | 07:10 AM
erikthegoalie's Avatar
Question best way to remove power steering pulley?
what it says in title...
THANKS
e
Old Apr 28, 2006 | 07:56 AM
ThaLS1KidII's Avatar
Rent the pulley puller from autozone and use it...
Old Apr 28, 2006 | 08:55 AM
TAQuickness's Avatar
or buy one for $15-$20 and use it
Old Apr 28, 2006 | 09:01 AM
Yup... That works too.
Old Apr 29, 2006 | 06:25 AM
ok, but how do you even get to the dam thing....remove the pump???
the radiator pipe is RIGHT in front of were you have to unscrew it....
do you use some sort of allen key to get it off the pump or what.....then when you get a pulley puller...where the hell do you put that? around the outside edge of the pulley...wont that damage the pulley...
Old Apr 29, 2006 | 10:04 AM
?!?!?!??! Ttt
Old Apr 29, 2006 | 11:50 AM
Danny2tek's Avatar
^bump^
Old May 1, 2006 | 05:36 PM
John_D.'s Avatar
There's something like a raised ring or ridge in the middle of the pulley, where a bolt would be, if there was one, holding the pulley on. The puller catches that ring.
You also need an SAE bolt or stud/nut combo to pull the new pulley on. I don't know the size but I know it was not a metric thread.
