which headers
Old Nov 3, 2002 | 01:01 AM
thefast1's Avatar
Default which headers
i have heard the shorties dont really help that much but i dont think i need the long tubes.im just going to do a few bolt ons (cai,cat back,high flow cats and y,plugs and wires maybe a programmer).which set do you think would be the best.also would like to have them coated so they look good too.
Old Nov 3, 2002 | 01:37 AM
INSSANE's Avatar
Default Re: which headers
Hookers, if you're not looking to sing big money, are the best. Second best Macs. Go with the Hookers though.
Nick
Old Nov 3, 2002 | 03:48 PM
thefast1's Avatar
will those work with the random tech y pipe and cats?
Old Nov 3, 2002 | 04:01 PM
Cody Brooks's Avatar
random tech. y and cats with hooker lts in a word, no.
hookers have an ory available seperately from hooker as well as mufflex. if you want cats then you have to buy them and put them in the y. if you can go without cats. or get a shell from a cat and put a piece of straight pipe through it the weld in on the pipe so that it looks like a cat. our cars are suppost to be able to meet emission standards without cats in all states except california or so i've been told.
Old Nov 3, 2002 | 04:16 PM
FstBlkz28's Avatar
the LT's wont work with the RT ypipe, but you could use the RT cats in a custom Ypipe or the Mufflex Ypipe.
Old Nov 3, 2002 | 06:09 PM
thefast1's Avatar
if i go with the hooker lts and the mufflex y with the carsound cats will i have to get any custom tuning done or have any ses codes.cant really have any tuning done around here as i live in the middle of nowhere(couldnt even get a set of 20s balanced for my truck right).
Old Nov 3, 2002 | 09:28 PM
thefast1's Avatar
with the setup i want will i still have to get o2 sims or can i use actual sensors.if i use the sensors will everything work right
Old Nov 3, 2002 | 09:33 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by thefast1:
<strong>with the setup i want will i still have to get o2 sims or can i use actual sensors.if i use the sensors will everything work right</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">go with simms and save yourself the worry of will it throw a code or not.
bigSS's Avatar
IMO the best bang for the buck is the MACS. I LOVE my Hookers, but for a bolt-on car i'm not convinced they'll gain you anything over the MACs.
Old Nov 3, 2002 | 09:44 PM
thefast1's Avatar
i guess i could do shortys(for looks more than anything)and the random tech high flow y with their cats,and a good high flowing catback.that would be the easiest way to go, what gains if any would i get.i just dont want to run into alot of problems later.
Old Nov 3, 2002 | 11:19 PM
TA_2001's Avatar
here is a header poll..
http://www.ls1info.com/pollBooth.php...rder=0&thold=0
I voted SLP
Old Nov 4, 2002 | 01:24 AM
thefast1's Avatar
looks like everybody likes the manifolds wonder why.i thought the long tubes were better
<small>[ November 04, 2002, 11:05 PM: Message edited by: thefast1 ]</small>
Old Nov 4, 2002 | 11:19 PM
thefast1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Cody Brooks:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by thefast1:
<strong>with the setup i want will i still have to get o2 sims or can i use actual sensors.if i use the sensors will everything work right</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">go with simms and save yourself the worry of will it throw a code or not.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">if i go with the sims what keeps the motor from running to rich or lean
Old Nov 4, 2002 | 11:22 PM
xaon's Avatar
simms are used on the rear o2 sensors. These are used only for determining whether the cats are functioning or not. If you don't use them, you'll throw a code... Using them does nothing more than eliminating the code. So no, they will not cause you to run lean/rich.
I put them on my car because I prefer my SES light to be functioning properly so it can notify me of a problem.
Old Nov 4, 2002 | 11:32 PM
thefast1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by xaon:
<strong>simms are used on the rear o2 sensors. These are used only for determining whether the cats are functioning or not. If you don't use them, you'll throw a code... Using them does nothing more than eliminating the code. So no, they will not cause you to run lean/rich.
I put them on my car because I prefer my SES light to be functioning properly so it can notify me of a problem.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">so why use them instead of the actual sensor,im going to use cats so wouldnt everything work like stock
Old Nov 5, 2002 | 01:09 PM
promod1955's Avatar
the front o2 sensors determine air/fuel ratio. these are located before the cats and are used on any exhaust setup regardless of long tubes or not. the rear o2's determine if the cats are working.
Old Nov 7, 2002 | 02:56 PM
Serial Thriller's Avatar
The MACs are available w/ or w/o cats. Are the cats that come with them worth a crap?
