LS6 intake?
Old Nov 6, 2002 | 10:13 PM
johnster's Avatar
Default LS6 intake?
Got a LS6 intake today.what do I need for install?I am putting it on a 98 T/A.It has the EGR. thanks
Old Nov 7, 2002 | 06:39 AM
oOoLy's Avatar
Default Re: LS6 intake?
I think you only need intake gasket.
Adnan
Old Nov 7, 2002 | 07:33 AM
Toxic Texan's Avatar
You need the coolant lines that run under the intake. They are not the same as ours. Also you have egr and the LS6 is not made for egr. This is my LS6 intake. In the pic you see a black tube going into the intake. We made the egr work with the LS6 intake. If I were to do it again I would just leave the egr off and get it deleted with LS1Edit. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Close up of LS6 intake.
<small>[ November 07, 2002, 07:35 AM: Message edited by: Toxic Texan ]</small>
Old Nov 7, 2002 | 10:08 AM
johnster's Avatar
Hey man did you paint yours.Mine has the EGR it is the one from SLP.
Old Nov 7, 2002 | 11:34 AM
Yep it is painted to match the car with clear coat. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 7, 2002 | 02:24 PM
johnster's Avatar
i have been told that you can reuse the intake gaskets?
Old Nov 7, 2002 | 02:32 PM
robertbartsch's Avatar
The intake gaskets are really part of the intake and can be re-used. ..replacement gaskets are expensive and not needed...
The replacement is straight-forward. The long Bolts are a pain since the old unit must be pulled with the back four bolts in place ...same with the install...i used duct tape to hold them in place when removing and installing...
...you also should port your throttle-body and consider using a bigger MAF, cold air box and lid....These made a big power increase for me .. about 25HP or so...
Old Nov 7, 2002 | 04:01 PM
Z 2 L8ter's Avatar
I was thinking of purchasing a LS6 intake also. My car is a 98 so I have the egr. Would it be better to get the egr intake since I don't have LS1 edit? I would prefer taking the egr off completely but is it worth it to spend all that money on edit to do this job or can I find a shop or something to delete the code? Thanks.
Jeremy
Old Nov 7, 2002 | 06:49 PM
johnster's Avatar
Thanks guys <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
