High compression 11:1 and potential detonation
If so, is it only when the temp gets above 100 F.
I ask because I am just about to install AFR heads and 40 thou headgaskets on my 2001 C5 which will give 11:1 comp ratio.
I am told by several tuners in Australia, which is where I live, that this is very high for a two valve/cylinder engine and I may experience some problems with detonation. Hence, I may experience timing retardation well below peak power.
Octane rating will obviously effect this scenario. The octane rating in Aus is 98 RON, whereas it is 93 in the US (an average of the MON and the RON). I have been told that the two octane rating of the two fuels, i.e., 98 RON, and 93 (average of MON and RON) are equal,
Does anyone have any input/knowledge here please ?
I would prefer to not pull off the heads again and change back to standard head gaskets because of loss of power resulting from excessive retardation if possible.
I basically want stock driveability, and as much power as possible.
Along with the AFR 205 heads, I have an underdrive pulley, kooks headers and cat back exhaust (standard mufflers though, vararam, ported throttle body and a 78 fast intake (did not go the 90 because apparently these give exactly the same drivability as the LS6 intake).
DCR versus SCR????
SCR = static compression ratio
SCR is when you say X amount of cubic inches compressing to Y amount of cubic inches, very easy to calculate.
DCR is when you take into account the SCR and the individual valve events. You now have to consider things like how much is actually being sucked in, how much is actually being exhausted, and how fast. When people say "The cam bleeds off a little compression....", they're talking about DCR.
Since the camshaft effects on these cars seem to be pretty close to the same, unless its some sort of custom job, most people pay most of their attention to the SCR.
It's all in the tune.
