WTF is that RATTLE!?
Old May 3, 2006 | 09:43 AM
Luna's Avatar
Originally Posted by Justin00SS
Have you ever removed your center console for anything? Take it back apart to make sure you didn't leave anything in there. Screw, bolt, socket.
Also, have you ever replaced your window motors? Check inside your doors. I lost a nut when I replaced my window motor on my drivers side. I couldn't find it so I said **** it. Its not that big.
That little tiny son of a bitch rattled like a **** until I got a magnet in there for about an hour and found it.
I think its something in your console.
Yes I've taken the center console out several times, I'll check it out today since I'm also going to check out the torque arm bushing and try to fix some squeeling belts/pulleys
Old May 3, 2006 | 11:36 AM
MPFD's Avatar
11 Second Truck Club
I had a bad rattle at certain RPM levels. couldn't figure it out. It was a loose cap on my aftercat o2 sensor. I looked up and down trying to find the rattle. when I did I tac-welded the cap down to the sensor and it went away. maybe look at you o2 sensors.
Old May 3, 2006 | 03:15 PM
Luna's Avatar
I FOUND IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The rattle was coming from the flimsy *** stock torque arm flapping all over the place and smacking the loop on my driveshaft safety loop. I shimmed one side of the loop with washers and shoved some heater hose in between the loop and the torque arm (just incase) and TADA! its fixed.
The torque arm and the driveshaft loop were BARELY touching which is why I never noticed it because from the front it looks like it has about 1/8" of clearance but its touching at the back. God I'm glad thats fixed it was ANNOYING!
