Do Granatelli mafs work?
<small>[ November 17, 2002, 07:36 PM: Message edited by: onebadss ]</small>
If your fuel/air happens to be spot on before then the GMS isn't going to help much. If it's off and the GMS happens to put it where it needs to be then you'll pick up power. Or...if there was knock retard caused by a lean mixure before and your GMS happens to richen the mixture you'll pick up power. Or...it could be that the GMS lean the mixture too much and causes KR.
MAFs vary (yes, even GMS "calibrated" MAFs) and cars vary. So, some will gain where others will lose. Some will stay the same.
As far as the smaller stock MAF being a flow restriction, it doesn't seem to hinder my car at all.
<strong>I still feel that the best MAF is a stock MAF with the screen removed. There are other ways to adjust timing advance and AF ratio without a fancy "recalibrated" MAF sensor.
As far as the smaller stock MAF being a flow restriction, it doesn't seem to hinder my car at all.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree.I had one when why car was stock and it ran 27 degrees timing WOT all of the time. The problems started when I modded the car and eventually set 2 hard codes running lean (which is 25% too lean). I also had idle surging problems and hard starts where before I didn't.I put the stock descreened one back on and all problems and codes went away and haven't come back since.
If you have evidence of descreened MAFs causing problems please fill us in. All the evidence I've seen is to the contrary.
ORIGINAL QUESTIONIST If you were to look at all my mods, will you be able to determine if it helps or hurts my car. No. But you could Autotap to get an idea of where you mixture is and exactly what you timing advance is but even if they are off I'd recommend LS1Edit or a MAFT to correct it. Easy adjustments and easily reversible.
<strong>What I was asking would it make a difference going from a GMAFS to a stock sensor with ported plastic ends.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The stocker with the ported ends would no doubt be leaner and with higher timing advance. This could be good or it could be bad. What you don't want is lean induced knock retard. It's also no good to go porting MAFs with an A4. It lowers the line pressure which is a bad thing.
