What kind of mufflers are these? Muffler selection for true dual over axle?
This looks like an LT1 car, but I'm interested to hear what this sounds like. Any idea which muffler this guy is using and what straight-through muffler would work well on a true dual system?
<img src="http://www.camaroz28.com/~chris/mmexhaust/pic00005.jpg" alt=" - " />
<img src="http://www.camaroz28.com/~chris/mmexhaust/pic00003.jpg" alt=" - " />
ls1's with true dual exhaust usually use dynomax bullet mufflers. which are similar to those. It sounds pretty bad ***, wish i had a sound clip for you. Im sure someone will post up though
That looks like Hot Rod Hawk. Check in the Mich section, camaroz28.com. I believe they are Dynomax.
If you want a more compact mufler, go with the Eldebrock RPM mufler, 3.60" thick, 7" wide. Great sound. Good luck.
That car is Hotrodhawk's.. that pic was taken years ago when dual exhaust was taboo. That is the old Modern Musclecar building which is now Aggressive Auto. The mufflers are a Dunomax Canister Bullet. I do not believe you can still get those.
Hes running a dual setup with an H-Pipe with moroso mufflers dumped before the axle now i believe.
They are DynoMax Race Welded round mufflers.
They are straight through. Designed just like the DynoMax Race Bullet on the inside, except it has more insulation.
Cost is a little over $100 each.
Dave
Dave
