Trouble with my A/F guage
Old Nov 18, 2002 | 09:51 AM
Jay 2001 TA's Avatar
Default Trouble with my A/F guage
I installed my a/f ratio guage a while ago and it has never quite worked right. It has power but the meter only displays in one position the whole time. The guage does not sweep at all.
I used a A/F wiring harness the plugs in line with a rear 02 sensor and ran the signal wire to it.
Does anyone have an idea of what is wrong? Thanks in advance for any input! <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Nov 18, 2002 | 11:32 AM
cantdrv65's Avatar
Default Re: Trouble with my A/F guage
You shoudl be on the FRONT o2's. The backs are simply used to indicate proper cat operation.
Old Nov 18, 2002 | 11:43 AM
haaa ok, thanks!
Old Nov 18, 2002 | 01:23 PM
fastbird350's Avatar
if the front O2 sims don't do the trick grab (wire 69) purple w/white strip from your computer
Old Nov 18, 2002 | 01:46 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by fastbird350:
<strong>if the front O2 sims don't do the trick grab (wire 69) purple w/white strip from your computer</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ok thanks, I will do that as a last resort. It scares me even thinking about messing around with my PCM. I guess im a wuss. LOL!
Old Nov 18, 2002 | 02:17 PM
justin sutton's Avatar
Just tap onto the wire when it comes out of the pcm.
Old Nov 18, 2002 | 02:28 PM
ok, thanks again everyone for your input. I am going to mess around with this tommrow morning. I am going to try the front 02's first. If that does not work then I am going to tap into the PCM. I will let you know what happens. Thanks!
Old Nov 19, 2002 | 02:15 PM
ok, i checked it and it actually was installed on the front 02. So I have no clue whats wrong with it. I am going to buy some of those wire taps and tap into the purple and white PCM wire and try that next.
Old Nov 19, 2002 | 07:45 PM
WILWAXU's Avatar
Moving to the Computer & Tuning section.
