Over axel True Duals..
Best bet is this setup:
3 inch to 2.5 x piped and over the axel with 4 bullet's.
2 Bullets before the axel and 2 after the axel.
They think this will be the Best sounding setup and they say they can tuck it up real nice.
They aint cheap but its worth it.
A good catback is 800 bucks so I guess from header back over the axel it isnt as bad as first thought.
Meent.. WOW.. Love your car to death.
I need those rims damnit!
I guess after the super charger and then the heads.. maybe alittle juice.. I will throw my concentration back onto the appearance.
Right now.. I have the chrome z06 rims.. BOOOOORING
Since it is mandrel bent.. 1500 bucks.. OMG!
But eh, do it right once.. never do it again.
It is able to be removed without cutting so I can access my trans
Let me put it to you this way. I have simple 2.5" duals dumped at the axle, with an x pipe and bullet mufflers. The entire setup cost me $200 including parts/installation. So you are saying its worth paying almost 8 times as much to have teh exhaust go over te rear axle and extend to the back? No way man, I'm sure someone out there can do just as good of a job for a much lower price.
hell speed inc will do a cam kit installed and tuned for that price.
you get way more power from a cam compared to an exhaust.
You'd get a lot more out of your cam kit if you put a good exhuast on it
i have long tubes, catless y pipe going threw a hooker exhaust.
duals will give some better power under the curve, but its not worth 1500 dollars.
and really makes me appreciate how my car sounds. I want the exhaust to look sick.. BE ABLE TO BE TAKEN OUT (none of yours are) without cutting, and be tucked up as high as possible.
The company that is doing this used to run Kooks.
So they know their ****. Pretty much I am getting kooks true duals.
can you provide a link to this set up?
Meent: that's a bichin' lookin' set-up. You have no clearance problems over the panhard bar? Nothing touches the floor pans, or fuel tank heat shield?
I had a bich of a time getting the over-axle pipe on my Magnaflow to clear the fuel tank heat shield. I must have loosened, adjusted, lengthened/shortened, and clamped/un-clamped that cat-back 15 times before I finally got everything just-so.
Did the shop offer you different tail pipe options?
Are the wheels ROH Snypers?
