extending 02 sensor
Old May 5, 2006 | 09:10 AM
ohsofast's Avatar
Default extending 02 sensor
My seller with 02 extension has backed out, so I am going to make my own 02 extension. My queston is what gauge wire do I need. Some one said if I use the wrong wire it will still set off a code. Any help would be appreciated.
Old May 5, 2006 | 09:37 AM
Xtnct00WS6's Avatar
I extended mine after they burned up a bit. I just eyeballed it, but if you're worried just go a bit thicker and you'll be fine.
Just make sure you're connecting the right wires together. I believe there are 4 all together.
Old May 5, 2006 | 09:47 AM
ohsofast's Avatar
Thanks, I will be getting the wires today.
Old May 5, 2006 | 09:51 AM
Z28LS1camaroguy's Avatar
yeah i just did the same thing when my o2 sensor plug burnt up from the contact with the header since the extension was to long, and i just use the rear O2s plug and cut it where i need it and spliced the new plug to the front O2s wiring. problem fixed.
Old May 5, 2006 | 10:41 AM
daryl2cb@yahoo.com's Avatar
becareful extend one at once, there are two purple wires, that are easy to mix up. 14 guage should be ok if it is stranded. other than that regular 16 guage is fine.
Old May 5, 2006 | 12:00 PM
ohsofast's Avatar
Would I be able to go to advanced and get that gauge wire, someone here said they have it at Home Depot
Old May 5, 2006 | 01:34 PM
TheBlurLS1's Avatar
That's what she said...
Yes, they usually have a selection of wire at advance. They also have some electrical connector kits with buttsplices you can pick up.
Old May 5, 2006 | 01:47 PM
ohsofast's Avatar
Thanks everyone I am leaving work now to get my pieces. Tomorrow is the day.
Old May 5, 2006 | 01:48 PM
actually the two wires that are the same color are the brown wires not the purple wire. just look at the plug itself and match it up before you cut it and then remember which is which, plus they are labeled with A,B,C, and D so just remember and dont mix those two wires up.
Old May 5, 2006 | 01:51 PM
'02 SLP#686's Avatar
Or just buy the rear set of O2's for a C5 - a little more pricey though.
