which is it?
Old May 7, 2006 | 12:54 AM
aNuBiS's Avatar
Default which is it?
Correct me if Im wrong here, but I emailed march performance asking them if the alternator pulley included in their kit was overdrive, or underdrive or stock size. They couldnt give me a straight answer, so I asked them what belts were suggest for either just the crank pulley, or the crank WITH alternator pulley, and this is the answer I got.
4521 balancer only: use Dayco 5060760 alt.; 5040378 A.C.
4505 power and amp kit: Dayco 5060755 alt.; 5040378 A.C.
So as I was saying, correct me if Im wrong, but from what I understood the last two numbers in a belts part number is the size. So would I be accurate in my assumption then that the alternator pulley is underdriven because the belt suggested for the crank with alt pulley is a 55, whereas the belt suggested for just the crank and factory alt pulley is a 60.
It is pretty late, so maybe Im just burnt out, lol. Let me know
Old May 7, 2006 | 01:06 AM
TheBlurLS1's Avatar
That's what she said...
Where are you getting these numbers from, and what are you trying to get? Which pulley(s) do you want?
March only sells an underdrive crank pulley. Overdrive would be pointless, as would stock.
Old May 7, 2006 | 06:27 AM
Viper's Avatar
TheBlurLS1
He said alternator pulley. Which they do sell.
http://www.thunderracing.com/catalog...1&sid=343#P432
Old May 7, 2006 | 08:10 AM
aNuBiS's Avatar
I want an underdriven ALT pulley to go with my underdriven crank pulley.
But the guys at march werent able to clearly tell me if their alt pulley included in their kits were over or under.
and I got those numbers emailed to me directly FROM March.
Subject: Re: question
Old May 8, 2006 | 11:02 AM
aNuBiS's Avatar
anyone else?
Old May 8, 2006 | 03:53 PM
aNuBiS's Avatar
so nobody on here actually bought the kit with the alt pulley, and can tell if its larger or smaller than the original? Guess I'll find out myself in a week or so and let ya'll know.
Old May 8, 2006 | 05:39 PM
Viper's Avatar
Why not call Thunder Racing and ask them? Sorry, I only bought the main pulley and belts ( gtom TR )
Old May 8, 2006 | 05:58 PM
TheBlurLS1's Avatar
I am not seeing this kit for an f-body on thunder's site. Where exactly did you find it?
It did not seem to show the underdrive alternator pulley anywhere on there for an f-body.
Old May 8, 2006 | 06:24 PM
Viper's Avatar
OK, I concede. I don't see it on TR's site either, sorry for trying to correct you TheBlurLS1. Anubis, where are you buying it from?
Old May 8, 2006 | 06:51 PM
aNuBiS's Avatar
http://byunspeed.com/product_info.ph...bdc0ba08503ae8
I havent called Thunder, cause exactly, they dont carry it.
However, as stated above, I did call March themselves and I couldnt get a straight answer outta the guy.
http://www.marchperf.com/pg1.html right at the bottom #4505
Part #4505 Camaro/Firbird dampener crank pulley and power and amp alt pulley.
Old May 8, 2006 | 08:27 PM
aNuBiS's Avatar
AHA! Summit sells them aswell, and as usual, nobody there can really tell me if its underdriven or overdriven, but from the picture if its of the actual product.... it looks pretty underdriven for an alt pulley maybe?
http://store.summitracing.com/partde...5&autoview=sku
Old May 8, 2006 | 08:31 PM
TheBlurLS1's Avatar
A smaller alternator pulley would mean it would be OVERDRIVEN. For every inch of belt that passes over it, it would spin more times, and produce more power.
