Changing generator bracket???
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Accessory Drive Belt - Squeak/Chirp Noise
BULLETIN NUMBER: 00-06-01-008
SECTION: 06 - Engine/Propulsion System
DATE: March 2000
TECHNICAL
SUBJECT: Accessory Drive Belt Squeak/Chirp Noise (Install New Double Row Idler Pulley, Generator Bracket and Serpentine Belt)
MODELS:
1998-2000 Chevrolet Camaro
1998-2000 Pontiac Firebird
Built Prior to VIN Breakpoint Y2107225 with 5.7L V8 Engine (VIN G - RPO LS1)
CONDITION
Some customers may comment on a squeak/chirp noise coming from the accessory drive serpentine belt. The noise will be most noticeable at idle and low engine speeds.
CAUSE
The serpentine belt squeak/chirp noise may be caused by misalignment between the idler pulley and crankshaft pulley. A slight rocking motion of the idler pulley causes the misalignment, which results in noise.
CORRECTION
To correct this condition on vehicles built prior to the above VIN breakpoint, install the new generator bracket, double row idler pulley and serpentine belt following Service Manual procedures.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<strong> I see on the TSB it says to change the generator bracket as well. Is this the bracket the idler pulley bolts into? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No it's the bracket that holds the alternator in place, I remember reading a TSB about this problem and I believe it showed what was needed to complete the work. That web site is no longer around but you should be able to get all the parts info from your dealer parts guy. What web site did you get your info from? Good luck.
Al
Al</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This one. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Looks like I will have to take off the alternator, swap the bracket, then put it back on. Hopefully it won't be too hard. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
If I remember correctly, the Idler pulley does bolt on to the Alternator bracket.
There is one bolt that is on the back side of the Alternator that was hard to get to. I had to use a piveting socket head to get at it.
Good Luck!!
<strong>I just did this a couple of days ago. Not hard at all, took me about 30 minutes to do the idler pulley, bracket, and belt.
Good Luck!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sweet! now that's what I was wanting to hear. Thanks! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
