e-cutout problem
Old May 9, 2006 | 10:09 PM
01350ss's Avatar
Default e-cutout problem
I picked up 2 electric coutouts and installed them right off the headers, then the y-pipe. I started the car and everything was fine, I opened the cutouts, then closed them. Only once! Now 1 of the cutouts (I think its only 1) will not fully close unless I hold the switch. What the hell happened. The cutouts are new from QTP. I have the flowtech cutouts, then the e-cutout, then another 3 bolt flange with a turndown. Is it possible that the plate is hung-up, or am I looking at taking this thing off the car again.
Old May 9, 2006 | 10:14 PM
slow trap's Avatar
how long do you have to hold the switch before they are closed ? it will take a couple of seconds for them to open and close.
Old May 9, 2006 | 10:50 PM
01350ss's Avatar
I think it's about 5-6 seconds (me counting). thats not the problem though. I can hold the switch, the plates close, exhaust sounds normal thru the catback, once I let go of the switch, 1 or both of the plates crack open.
Old May 9, 2006 | 10:54 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
My QTP's did that too. If you tap it a few times sometimes the motor in the cutout will push them shut a little better. It is literally blowing it open just a bit.
Old May 9, 2006 | 10:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
And just so you don't screw them up like i believe I did to mine. Don't push and hold the switch. The motor will over heat and weaken...then over time the mechanism will break. Only move it to open all the way or close. The longer you are moving them with the switch the worse it will get over time. They are a great product, but get a bad rep sometimes because they are being used incorrectly.
Old May 9, 2006 | 10:58 PM
01350ss's Avatar
If the exhaust is blowing it open, what the hell do I do about that? I can't drive this car with a small leak right off the header! Was this a continuos problem for you orangepeel? Thanks for the reply guys. I appreciate it.
Old May 9, 2006 | 11:13 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
yeah, it did it for a long time. That is why I was saying that if you tap on the switch 5-7 times sometimes it will suck it shut from vacuum or something.
Old May 9, 2006 | 11:41 PM
01350ss's Avatar
so should I tap the switch or the motor?
is this something i have to deal with for the duration that i have these?
is it even worth having with no cats and the slp dual/dual
Old May 10, 2006 | 12:30 AM
01350ss's Avatar
just checked under the car. it seems like the passenger side "gate" can move very little with my finger. I haven't gotten back under the car cause I'm all cleaned up now, but is there a possiblity that the cutout is already loosening up or comming aprt?
Old May 10, 2006 | 12:39 AM
01Z28M6's Avatar
Mine leaks too and I think they all do. What I do when it doesn't close properly, which is most of the time is to tap it open a fraction and then close it by tapping the switch the other way. Sometimes I have to do this cycle several times but eventually it gets close enough to being closed.
Electric cutouts haven't caught up with today's technology yet.
Old May 10, 2006 | 02:36 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You might have more luck in calling QTP and explaining what is going on with it.
Old May 10, 2006 | 08:52 AM
jimmyblue's Avatar
Moderator
Mine stays shut fine, do not know about the QTP
construction but you might need a limit switch moved
a little bit to get preload on the plate, or something
like that. On mine there are open and closed limit
switches that stop the travel (McCord Power Plate).
It needs to travel just -barely- into bind, butterly to
seat.
Old May 10, 2006 | 10:15 AM
01Z28M6's Avatar
Looking at your sig I can see you don't cut corners. Yours is the first post I've encountered about closing e-cutouts in the positive. Limit switches are what mine and most others lack. Apparently the McCord power plate is the next step.
Old May 10, 2006 | 10:31 AM
jimmyblue's Avatar
Moderator
Well, without a limit switch there should be nothing to
prevent it traveling all the way to bind; should be a
good thing (other than, you could keep putting power
to a locked rotor indefinitely).
Old May 10, 2006 | 10:46 AM
01Z28M6's Avatar
And that's where we end up burning the motors out. The limit switch is a necessity imho. Always good info from you. Man I love those 10 spokes.
