clear lid
Old May 11, 2006 | 12:07 AM
1slowls1's Avatar
Firehawk 608 and randy ws6 nice clean engine compartment shiny
Old May 11, 2006 | 02:08 AM
staringback05's Avatar
i think they look sick, just dont feel like ditchin my black one and dropping 120 bucks right now
Old May 11, 2006 | 09:21 AM
Mike02Z's Avatar
I have the TSP smoked lid. Too bad they don't make them anymore. I have not had mine crack yet and it's been on for almost 3 years.
Old May 11, 2006 | 12:16 PM
rubber duck's Avatar
for those asking
K&N=red
Holley=blue
Green=green
Old May 11, 2006 | 12:55 PM
taintedmeat's Avatar
Originally Posted by rubber duck
Green=green
Old May 11, 2006 | 01:05 PM
Wino's Avatar
I bought mine used and it had some scratches but it was cheap.
W/ K&N
Old May 12, 2006 | 12:05 AM
Originally Posted by taintedmeat
the company is actually called Green air filters. It just happens their air filters are green.
Old May 12, 2006 | 07:52 AM
Sweet, I see them on LS1Speed, thank you
Old May 12, 2006 | 09:16 AM
BlazinT/A's Avatar
dont the 01-02 cars have a air line coming off the air lid? do you just put a breather on the motor sie of the hose or do the lids come with the hose and hole for it?
Old May 12, 2006 | 10:06 AM
KY Z28's Avatar
I have a clear MTI lid on my car and I just put a small K&N breather on the end of the AIR hose. I will eventually delete the entire AIR system once the headers go in, though. The only lid that I know of that has the AIR provision is the SLP and that is because it came factory on some SS cars and needed to be compatible.
Old May 12, 2006 | 01:15 PM
Mike02Z's Avatar
You can actually see my breather on my picture above^^. I zip tied mine to the ABS control unit.
Old May 12, 2006 | 06:56 PM
  #32
H8 LUZN's Avatar
I need to polish mine.. from working on the engine bay all winter.. it kinda got slightly scratched...
I would not choose another lid though, the clear one is hands down the best!
Old May 12, 2006 | 08:43 PM
  #33
Louie83's Avatar
Originally Posted by FIREHAWK#608
I got mine from MTI about one year ago. $120.
If you work on the car take the lid off and don't let anything but a micro fiber cloth touch it. They scratch easily. I knew about the scratching and used these steps from day one and it still looks like new one year later. Here's a picture:
I'm waiting until you come out with that clear bellow before I order mine.
Hurry up!
Old May 13, 2006 | 10:44 AM
  #34
RedWS601's Avatar
hope I am not hijacking
Is there anyway to get the clear lid to look like new again? I was looking at Firehawk608's lid and can't remember mine looking like that.
Old May 13, 2006 | 11:53 AM
  #35
~JOSHUA's Avatar
You can polish the plastic using a special buff and plastic polish. You can hook the deal to a corded drill and make it happen.
If it's scratched then forget about it; if it's simply lost it's luster you can polish, but be warned!- Plastic can be burned by the buff easily if you spend more than 3 seconds in the same spot and if you try to get results too quickly.
When you call Eastwood tell them you need a "wheel arbor" to mount the 1/2" hole buff to your corded drill. They will hook you up. It should cost about $5.
Plastic supplies....
Buff Wheel 6 Inch String
For Extremely gentle Buffing On Plastic
Bring side markers, turn signals, tail light lenses to shiney, like-new condition. Thousands of 1 3/4" long cotton strands reach deep into details to gently polish and shine without overheating and melting plastic. Use with Plastic Buffing compound.
13029 Buff Wheel 6 Inch String 1/2 Inch Hole $24.99
Autosol Metal Polish
World-famous Autosol polish provides a brilliant gloss and long-lasting weather protection on all metals from aluminum to zinc. It removes rust and oxidation without excessive abrasion - perfect for chrome and nickel plated parts. Great for polishing fiberglass and plastics, too. 13170 Metal Polish 100gm Tube Autosol $9.99
Old May 13, 2006 | 12:14 PM
  #36
EDS01SS's Avatar
Heres a pic of what I did with my A.I.R breather
http://img.photobucket.com/albums/v2...install005.jpg
Old May 18, 2006 | 03:14 AM
  #37
1slowls1's Avatar
Why wouldnt you just go to wal-mart and buy the mothers buffer ball attaches to a drill. its like $15
Old May 18, 2006 | 04:32 AM
  #38
00454sscamaro's Avatar
as for the color of the filters.. the k&n is actually white untill you put the k&n oil on it but you can use green oil or blue oil to change the color.. k&n recomends using there oil, but dirtbike air filter oils just as good.. i got a question for the clear lid though is it any bigger then an slp lid, when i got my car an slp lid was already on it.. but i heard the granatelli and a few others flowed better.
Old May 23, 2006 | 05:06 PM
  #39
GIGAPUNK's Avatar
Are there any clear lids that match up to the 85mm MAFs?
I'm building up a 2003 Longblock and am looking at a 90mm TB, and already got the 85mm MAF, don't need to add a restriction at 78mm.
