questions about installing headers
Be sure to have a 10mm Rachet end wrench, it makes it so much easier and faster.
If the drivers header gets stuck on that little casting that sticks out of the block just stick another jack and a piece of wood under the header and force the header up which will move the engine on the mount over a little to give enough room for the header to pass through. Also be sure to get the car very high up in the air, the higher the better.
Oh yeah the best advice is to be sure to install poly motor mounts after you get the stock exhaust out and before you put the headers on. Evereyone says if they did it again they would do the mounts while doing the headers, so just take it from us, do the mounts while you are at it. It will ensure that your headers and y pipe will not bang the floor. If you dont do them now and want to do it later it is like twice as difficult with the headers in.
for what its worth my set up went in tit and is sturdy as hell (just ask the speed bump i hit last week)
I'm sure I'm going to run into various other things along the install, but that's all I can think of right now.
Any other tips?
P.S. I will be running open headers for a day or two
Any other tips?
NO you keep the Front 02 sensors you delete the rears. That is why you need 02 sensor extensions. The front o2 sensors are what monitors you fuel ratio the rears monitor the cats.
