Why does my car.....
Old Dec 9, 2002 | 12:12 AM
sconnor's Avatar
Default Why does my car.....
Feel like it's going to stall when I am slowing down. My car runs fine when I am on the gas but when I am slowing to either a stop sign or a traffic light my RPM's drop to 400 and once the car is stopped it goes back to 900 RPM's. The mods I have are Hi flow cats, Cat back, BBk 80mm T/B, Gran. MAF, MAFT, and SLp smooth bellows kit. The only code I am getting right now is 420 which the dealer is blaming on my hi flow cats. Any help would be appreciated.......Scott
Old Dec 12, 2002 | 05:31 PM
WILWAXU's Avatar
Default Re: Why does my car.....
to the top
Old Dec 12, 2002 | 06:17 PM
Dope's Avatar
I would try going back to the stock MAF and/or stock TB and see if the problem goes away.
Dope
Old Dec 12, 2002 | 06:24 PM
Sears's Avatar
!Dial-up Director
Probably the BBK throttle body, Put a stock T/B on and see if the problem stops.
Justin
Old Dec 12, 2002 | 09:36 PM
sconnor's Avatar
I have had the mods on since I bought the car about a year ago and my problem has just started within the last month or so....
Old Dec 12, 2002 | 09:49 PM
deviate42's Avatar
its the tb or MAF.
Unplug all the sensors(around tb and MAF, and lid), flip the car to run, let it sit in run for lik 30 secs, then turn off, plug up correctly and tightly all the connections and sensors, and turn the car to run and let it sit in run for 5 mins. Start the car and see if its better.
***I think this is the correct way to do this. If someone could reply to this to see if im right b/c i dont wanna give wrong info
my friend forgot to hook up his MAF sensors after installing a lid. I think he described kinda what your describing. Hope that helps
Old Dec 12, 2002 | 10:14 PM
sconnor's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SSpeeed:
<strong>its the tb or MAF.
my friend forgot to hook up his MAF sensors after installing a lid. I think he described kinda what your describing. Hope that helps</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'll give it a shot. But it started long after installing the mods...
Old Dec 13, 2002 | 07:52 PM
fastflames's Avatar
first off check your engine sensor fuses in the fuse box closest to the headlight. If this isn't it, an o2 sensor may be going bad or your maf may be going bad.
Joe <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
