Throttle body stop mod
Old Dec 11, 2002 | 09:06 PM
John02Z28's Avatar
Default Throttle body stop mod
Who has done this? How much do you grind off? How do you know when enough is enough?
Thanks John.
Old Dec 11, 2002 | 09:16 PM
Jake99SS's Avatar
Default Re: Throttle body stop mod
It's been a while since I did this. If you have Autotap, bring up the TPS Voltage parameter and grind until you see 4.6 or 4.7 volts at WOT. Maybe someone can confirm, you don't want to go past that value.
Old Dec 11, 2002 | 09:48 PM
John02Z28's Avatar
Cool, thanks I was told 4.9 was the wall but wanted some other thoughts. John
Old Dec 12, 2002 | 03:48 AM
SStrokerAce's Avatar
I do this on my ported units. I know how much I take off to get too much so I can leave it adjustable with a set screw, since I set the TB's up on a Mill and cut the area down in about 3 passes.
4.7V is the max you can go to, but it probably doesn't need to go that far for a full 90deg opening.
Bret
Old Dec 12, 2002 | 01:58 PM
eallanboggs's Avatar
The GM manual say the TPS DTC goes set at 4.65 VDC so you have to stop at 4.64 VDC max. It also says the closed throttle value should be NEAR 0.6 VDC. It doesn't say if it should be above or below that value so I set mine at 0.59 VDC. You need a Digital VOM to get this kind of accuracy.
Old Dec 12, 2002 | 02:40 PM
John02Z28's Avatar
You can use a VOM or must you use an A-tap to get your voltage numbers?? Thanks John.
Old Dec 12, 2002 | 06:39 PM
KatmanSS's Avatar
John,
I used the following info to do mine - it is from a post on this board by ND4SPD. Worked great.
Disconnect plug from TPS on opposite side of throttlebody. Pull back the rubber insulation so that you can place (3) small gauge wires in each of the (3) holes. Now you have to connect plug back to TPS but will have (3) wires sticking out. Turn on Ignition keeping wires separated (not touching one another). The 3 wires are for voltage, ground, and variable voltage. You need to hook the two voltmeter leads to two of the three wires. Hook one voltmeter lead to the blue (variable voltage) and the other lead to one of the other two wires. When you have this correct your voltmeter will vary from 0-5 volts when turning throttle blade manually. Now just grind stop and keep checking voltage with throttle held wide open to bumpstop until you reach desired voltage. I went 4.65vdc. Over 4.7 will set code so be conservative near the end. Mine went from about 78 deg. (4.41vdc) to about 90 deg. (4.65vdc) when done. If you have tcs you may have to adjust throttle cable length depending on how far you go with the bumpstop mod. I had to.
I hope this helps!
Old Dec 14, 2002 | 10:53 PM
John02SS's Avatar
My Bauer TB was set at 4.6 right out of the box via autotap. The blad is an almost perfect 90 degrees also. Don't see any need to go any further.
John
Old Dec 15, 2002 | 05:26 PM
You just take a tiny sewing needle or tiny push pin and push it thru the insulation of the blue wire to the TPS to get the output DC Voltage. You attach an alligator jumper to the needle or push pin and attach the other end of you jumper to the RED lead on your meter. No need to make up some complicated cumbersome connector jumper bypass assembly just to make one simple sense wire voltage reading.
Old Dec 15, 2002 | 08:28 PM
bomax's Avatar
http://www.ls1camaro.net/sections.ph...ticle&artid=26
Old Dec 17, 2002 | 11:58 PM
John02Z28's Avatar
Thanks for all the info guys, I really appreciate it.
John
