Which True Dual Setup???
Dual cutouts on a TD system that does not have cats would be pointless IMO.
As for the cats/resonator combo, I can't really say, since I've never heard that setup before. I would imagine it would still be pretty loud since your only real restriction will be the cats. It won't be quite as loud as say, open headers, but it probably won't be awfully far behind either. I used to be that loud with sweet thunder duals, and it does get old after a while. Did to me at least
Given your setup and what you're wanting, I would probably do dual cutouts after the headers somewhere, and slap on a quiet crossflow muffler, that way you can be quiet when cruising the interstate, and then open up and have the rasp-free true dual sound of the cutouts. A guy locally runs that setup, you would swear it was running true duals by how it sounds at WOT, but it's a dual cutout setup after the headers. This however is just my opinion
Unless of course you're looking for the weight savings of the duals, then scratch what I suggested
As everyone else said, it makes absolutely zero sense to have cutouts on a dual system that is running catless with resonators because there will be zero HP to be gained and not a ton of sound difference. I'd suggest having the duals fairly quiet with some larger mufflers and running cutouts if you want a difference in sound sometimes (seeing as you won't lose any HP through the mufflers).
