Jethot Y Puipe
Old May 19, 2006 | 01:31 AM
Jpr5690's Avatar
Default Jethot Y Puipe
Long Time Ago I Vaguely Remember Some People Bitching About Jethots Shitty Y Pipe ..
What Wrong With The Pipe Does It Really Flow That Bad?
Old May 19, 2006 | 02:38 AM
02 BLK WS6's Avatar
Did you mean POOP???????
Old May 19, 2006 | 02:52 AM
Jpr5690's Avatar
?? Poop ? It Cant Be That Bad I Mean It Looks Like Every Onter Y Pipe Ive Seen Hell Whats The Difference?
Old May 19, 2006 | 08:39 AM
chris2000ss's Avatar
I have one with NO PROBLEMS !!! it fit great and was on sale at the time at a bargain price...
Old May 19, 2006 | 09:35 AM
jimmyblue's Avatar
Moderator
The merge is not very sophisticated, there was a lot of
excess pipe sticking in on mine and the turn is near 90
degrees with some reversion up the other side looking
likely. Also does not tuck up all that well on mine, though
maybe some quality time with the floor jack will fix it.
The cats are cute (insert inside the pipe) if you want to
say you have cats; they are small, metallic and blow
out often esp. for people with forced induction (more
heat, I guess).
But pipe is pipe and most look similar, except the QTP
(much better merge) which has its own tuck-up
problems I've heard....
Old May 19, 2006 | 12:41 PM
Dal1as's Avatar
The merge on the Magnaflow y-pipe is crap. Hell mine broke in half. It doesn't tuck up well and if you aren't running cats there are a bunch of useless pieces you need to clamp (I welded them) together. If you know someone good have them make you a custom y-pipe with a nice merge. The custom y completely changed the tone of my exhaust and the rasp and mechanical noise is almost gone.
Old May 19, 2006 | 12:49 PM
Jpr5690's Avatar
So Would It Make A Big Difference If I Took It Off And Dremeled It A Little Bit Inside ?
Old May 19, 2006 | 03:34 PM
Dal1as's Avatar
Smoothing the edges of all the pieces might help a bit but you're still going to have a lot of raw connections and there is not much you can do about the merge. It's not a horrible y-pipe it just could have been better. If you already have it just makes sure it's installed well.
Old May 19, 2006 | 03:55 PM
DannoWS6's Avatar
The pipe is ok.
The cats are useless. Mine blew out in less than 5k on the clock.
