Fast intake install
Old May 20, 2006 | 06:54 PM
BOTTLE ROCKET's Avatar
Default Fast intake install
For anyone that has installed a FAST intake;
1. Can you use the TB gasket (rubber) from the old Z06 intake, or will I need a new one since it is a 90mm? (you would think for the cost that these things would come with one)
2. Are their any obvious things to "port/clean up" on them that will slightly improve their performance without sending it off for a full port job. (There's no way the wife will let me spend $500 more right now!!!)
3. Is there anything else I'm going to need before I do this install. (I am taking a day off from work to install the intake, TB, Dave's N2O plate, and a high flow bridge, and I don't want to get hung up in the middle of it needing to order some fittings etc.)
4. Mike Norris just did a dyno tune on this car after I installed the heads. I have since installed a 3" x-pipe and will add the above items. Will I need to "re-tune"??
Thanks
Old May 20, 2006 | 07:30 PM
02RedHawk's Avatar
1) The FAST 90mm intake comes with a new gasket. Its in your box, in the baggie with all the other nuts 'n bolts.
2) Remove the "wedge" in the runners, and clean up any molding-flash on the parting-lines.
3) Runner gaskets, RTV for the MAP sensor (its a loose fit),
4) I would.
Old May 20, 2006 | 09:28 PM
Thanks RH
Found the TB gasket. I had left it in the large bag with the intake.
I wondered about the "wedge" in the runners. It's so obvious, it seems they would have elimiated it in the casting design. I wondered if it was part of the "design", and had some purpose.
Old May 20, 2006 | 10:10 PM
daryl2cb@yahoo.com's Avatar
just a guide for porting matching.
Old May 21, 2006 | 01:10 AM
35th SS's Avatar
get a hold of a dremel and shave those buggas out.I did.
Old May 21, 2006 | 01:34 AM
TheBlurLS1's Avatar
That's what she said...
Like stated before, it does come with a new O-ring for going between the TB and the manifold, it's folded in half and inside a small ziplock.
You can re-use the port gaskets from the old manifold, but mine have always seemed very flat. I ordered a new set from BYUNSpeed for $32.
I also should note that I had to bend my front coolant pipe down some so the bottom of the manifold (right by the TB) would not hit it. I just placed the wooden end of a hammer on it and tapped it with a rubber mallet.
Here's some pics of what I did to mine.
Old May 21, 2006 | 03:58 PM
35th SS's Avatar
nice shave job theblurls1.just like that.
Old May 21, 2006 | 08:09 PM
ws6formula98's Avatar
on the fast intake do you have to cut the hole for the egr that goes after the tb?because most of the fast intake install dont have the egr.
Old May 21, 2006 | 08:33 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would eliminate the EGR so you dont have to jack up the intake.
Old May 21, 2006 | 08:40 PM
MadBill's Avatar
One advantage of the two piece design is that you can apply a light colored coating to the gasket face then bolt the lower half loosely to the heads, jiggle it around a little for best alignment and use a 'U'-shaped stylus to scribe around the port openings to transfer the port dimensions as a grinding guide.
I found that the ports (GMPP CNC heads) and the FAST runners both slope a little from the vertical, but not at quite the same angle. Made for a bit more work.
Old May 22, 2006 | 11:17 AM
Ditmeion's Avatar
I talked with FAST about those "wedges" they say they are there to promote swirl & low RPM performance. They also said.... Removing them won't SIGNIFICANTLY help or hinder the overall performance of the intake.
Old May 22, 2006 | 12:20 PM
MadBill's Avatar
Well, that makes sense; they look too prominent to be accidental. It would have been smart of FAST to mention it in the instructions though, as even if the buyer didn't go to the trouble of grinding them off, he or she might well feel short-changed.
For the engine I was working on, low speed effects are of no consequence; it is strictly a track car. Power is still slowly rising at our arbitrary 6,800 RPM shift point, and revs will rarely drop below 5,000.
Old May 22, 2006 | 01:08 PM
I agree; It makes you think they were "sloppy" with the casting.
Thanks for checking DIT
Old May 22, 2006 | 01:30 PM
RGR Pete's Avatar
[QUOTE=02RedHawk]
And it will come out really easy after all done.
