any power gains with smooth....
Old May 20, 2006 | 07:02 PM
fbirdserge00's Avatar
Default any power gains with smooth....
Are there any power gains when replacing the factory bellow with a smooth bellow for ws6 store???
Old May 20, 2006 | 07:06 PM
radz's Avatar
dont waste your time or money, I have it only because it came in the kit I bought
Old May 20, 2006 | 07:07 PM
98_Formula's Avatar
search for the fernco mod, and save ur money!
Old May 20, 2006 | 07:33 PM
radz's Avatar
Also I forgot to metion earlier but check out www.universityinstall.com and do all the free mods if you havent already
Old May 20, 2006 | 07:56 PM
2K2WS6TA's Avatar
Mostly an appearance mod, maybe you get 1 hp, but likely not even that
Old May 20, 2006 | 08:07 PM
Jon B.'s Avatar
www.installuniversity.com
Fixed it.
Jon
Old May 21, 2006 | 12:36 AM
TheBlurLS1's Avatar
That's what she said...
Smooth bellow is responsible for the death of my first lid. I would not switch untill you make serious changes to the intake tract.
Old May 21, 2006 | 12:43 AM
staringback05's Avatar
blur how did the bellow kill ur lid?....ive just got some fernco on mine..
Old May 21, 2006 | 02:05 AM
TheBlurLS1's Avatar
It was too stiff and cracked the MTI clear lid pretty bad. This was before I had the poly motor mounts, so there was quite a bit more movement.
The stock bellow is meant to flex, which is exactly what it needs to do. You can see how much the motor rocks when you just rev it in the driveway, now Imagine how much it moves during a 1st gear rhomp.
Old May 21, 2006 | 02:30 AM
damn that sucks...i just heated mine till it expanded and didnt put pressure on the maf.....wait...didnt u have ur maf between the lid and the bellow....
ie....lid-maf-bellow-tb?
Old May 21, 2006 | 03:17 AM
TheBlurLS1's Avatar
Yes I had it setup lid/maf/bellow/tb.
The side-to side rocking and the constant bind it was in from being so hard to install is what did it in. The stock bellow allows for alot more movement.
I now have the NW90, stock bellow, stock MAF and MTI clear lid. It fits better than anything ever has (even the stock crap). The NW 90 sort of points up a little bit toward the lid opening. That 4-5* or so really helps it fit PERFECT.
Old May 21, 2006 | 10:26 AM
YouCantCmyZ28's Avatar
my biggest waste mod yet!
Old May 21, 2006 | 10:52 AM
LS69TA's Avatar
I got one because it looks better, and I got a good deal on it. Otherwise, I wouldn't waste my money on one.
