Headers Into Y-pipe Question
If you want non emissions headers, you'll get the light, but like I said you can have the error codes tuned out
The off road or catted Y really makes no difference, you'll need the sims unless you get the catted y with rear o2 fittings
Any other questions just ask away
FWIW I have pacesetters on mine, they fit great, and, so far, look good
If you have the cash, you can get the kooks headers and Y, but they're ~$1400, but they are stainless, and will probably outlast the car
If your budget is tighter the Pacesetters and Y can be had for ~$500 from various sponsors (speed inc, byunspeed, tsp)you can get the simms from them too
The pacesetters can be had with a ceramic coating (recommend getting them coated), but like all mild steel items they will eventually rust
IMO you'd be well to think about either getting cats, or a different catback, as the LM is going to LOUD and raspy when you do headers (if you use an off road Y)
If you want to change the catback, and use an ORY, try the hooker or the SLP dual dual, they're both pretty quiet until you go WOT
You can use a catted Y but you may run into clearance problems (depending on what cats/pipe you use)
FWIW I went with an off road Y due to the potential for clearance problems (the local roads suck)
Search around and see what brand of catted Y gives the best clearance, and get that (it will also depend on if you've lowered the car, or plan to)
