Quick Question about exhaust
Old Jan 18, 2003 | 08:34 AM
98 Blue T/A's Avatar
Default Quick Question about exhaust
I decided to have my muffler cut off and replaced with a custom y-pipe attached to the tips. I was just curious if this would hurt or help the car? It sounds great but I have heard people talk about an engine needing a certain amount of backpressure, not enough and you lose performance, too much (restrictive) and you lose performance. One thing I did notice is that when engine braking sounds good, thoaty, gurgling noise but when I start to get back on the gas it pops a couple times. So in your opinions, do you think I lost or gained performance. I have done, the FRA, and EGR mods and also had my MAF and TB ported. I will be getting a lid shortly. This is of course temporary until I get LT's with cutouts anyways, I like how it sounds was it worth it?
Old Jan 18, 2003 | 05:34 PM
Default Re: Quick Question about exhaust
Thank-you very much for the info, you guys are very helpful. One more question... Is the stock Y-pipe real restrictive? It looks like it would be compared to an aftermarket one? How much gain would I get from an aftermarket Y?
Old Jan 18, 2003 | 05:41 PM
deviate42's Avatar
mabe 5 hp
Old Jan 18, 2003 | 05:43 PM
deviate42's Avatar
* if you have highflow cats or if its a ORP, you will see more
Old Jan 18, 2003 | 06:53 PM
DONAIMIAN's Avatar
Aftermarket y-pipes are a waste of time. They also have less ground clearence. GM put thoes flat spots in there for a reason and thats for clearence reasons. You wont really get any more flow either, even though its flat spots in the factory Y in thoes same flat spots its wider so flow wont be effected.
Old Jan 19, 2003 | 12:04 AM
J'sRamAir's Avatar
What you did is fine. The less resistance you have with your exhaust the more power you will make.
Old Jan 19, 2003 | 12:20 AM
Satan's Angel's Avatar
What he said!
Old Jan 19, 2003 | 12:53 AM
DONAIMIAN's Avatar
Less back preasure is a good thing, some people might think they loose power, but the truth is they gained more on top at the expense of a little bottom.
Old Jan 19, 2003 | 02:16 PM
NX†C's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong> Aftermarket y-pipes are a waste of time. They also have less ground clearence. GM put thoes flat spots in there for a reason and thats for clearence reasons. You wont really get any more flow either, even though its flat spots in the factory Y in thoes same flat spots its wider so flow wont be effected. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">they do have lower clearance, but on the flip side to that is that they do provide for a more freely flowing exhaust. take the stock diameter of 2.5" in most areas and the then 1.75" in the flat areas, and hold that up next to a full 3" y-pipe. the difference is obvious but all depends on if you want to go out and get a custom y-pipe made for your manifolds. as Stang killer said this could be a waste of time and money unless doing headers at the same time.
i know from running an ungodly large y-pipe off the QTPs and being on a pro-kit to avoid noticeable areas of which scrapping is inevitable. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
