Longtubes are on, but car won't start...
Old May 24, 2006 | 02:44 PM
spazzyfry123's Avatar
Old May 24, 2006 | 03:18 PM
Scotty-Z's Avatar
Originally Posted by Luna
yea do you have fuel pressure @ the rails ? Check the voltage on the battery ? Make sure you didn't disconnect any of the wires connecting the coil packs or injectors.
Also, make sure the coil brackets are bolted to the valve covers as I BELIEVE that it how they ground themselves. You could also get one of those lights that you ground and stab a wire with ( Idunno what its called) to check the plug wires to make sure you are getting spark.
The fact that you are not getting any codes makes me think its something simple like fuel, power or spark.
Yeah, I'd think the same thing.
I can't say that I know an incredible deal about anything under the hood. I know my way around, but my buddy is the real expert. He went over everything twice and said it was all hooked up fine, so I don't know what it could be.
I think tonight we're going to borrow a trailer and take it up to his work to run a $5,000 scanner on it and see what's wrong.
Old May 24, 2006 | 03:22 PM
RrCoX22's Avatar
that sucks man... to have everything hooked up and it won't fire.... mmmmm
hey check your sig man they're installed now but not runnin'
Old May 24, 2006 | 03:25 PM
Scotty-Z's Avatar
Old May 24, 2006 | 03:36 PM
Mike02Z's Avatar
Maybe your VATS just took a dump at the same time? That would be my luck. There is a good write up on here about bypassing that. Worth a check if you or your buddy have an OHM meter. Do you hear the fuel pump prime when you turn the key?
Check out this thread for the hell of it...
https://ls1tech.com/forums/general-maintenance-repairs/502913-vats-taking-crap.html
Old May 24, 2006 | 03:41 PM
Scotty-Z's Avatar
https://ls1tech.com/forums/showthread.php?t=502913
That's what I thought too. I disconnected the sensor in the rear of the car that detects motion and such because I thought VATS might be pissed at me. Used a spare key and tried starting her then and she didn't work.
I removed the starter, checked the connection on the crank sensor again... and it's fine.
Old May 24, 2006 | 03:48 PM
ls1_doc's Avatar
did u check all the fuses ? the ones inside the car and under the hood ? Just a thought sometimes its the obvious.
Old May 24, 2006 | 03:50 PM
Scotty-Z's Avatar
Checked the two in the engine bay and the one on the driver's side. All seem to be fine, except I'm not sure what a blown larger fuse would look like (the gray cubed ones).
Old May 24, 2006 | 04:04 PM
98Z28MASS's Avatar
did you gap the spark plugs correctly and make sure all the plug wires snapped back into place on the plugs?
Old May 24, 2006 | 04:21 PM
Scotty-Z's Avatar
0.060 gap, correct?
Old May 24, 2006 | 04:44 PM
Z'mnypit's Avatar
So does the fuel pump kick on when the key is on? The realy went out on mine one day after I had parked the car. Took me forever to figure it out. You didnt remove any grounds did you?
Old May 24, 2006 | 04:46 PM
  #32
WhiteKnightZ28's Avatar
Tech Resident
Swap the fuel pump one with the AC one right next to it. Theyre the same size, mine had weird intermitiant problem that gave the same syptoms that your having, just switch the two and give it a try.
Old May 24, 2006 | 05:46 PM
  #33
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
...any luck ????????
Old May 24, 2006 | 05:48 PM
  #34
Scotty-Z's Avatar
Got home from the gym and I'm going to try some other stuff. If not, it's getting trailered to my buddy's work to find out what's wrong.
Old May 24, 2006 | 05:51 PM
  #35
NHRAMAN's Avatar
g'luck man...
Old May 24, 2006 | 05:57 PM
  #36
Scotty-Z's Avatar
Originally Posted by NHRAMAN
g'luck man...
Thanks.
I appreciate the support guys. That's exactly why I come here.
Old May 24, 2006 | 06:13 PM
  #37
chris93266's Avatar
keep us posted
Old May 24, 2006 | 06:27 PM
  #38
Mike02Z's Avatar
Don't forget to see if you hear the fuel pump prime when you turn the key to "on".
I know there is no reason why it should happen when replacing headers other than Murphy's law but my money is still on the VATS. Your key(s) may be fine but your lock cylinder may be what has gone bad. Happens all the time out of nowhere. Only way to know for sure is with an OHM meter.
Have you ever had an issue with the security light coming on in the recent past while driving?
Keep us posted.
Old May 24, 2006 | 06:51 PM
  #39
Scotty-Z's Avatar
Keep us posted.
As far as I've seen, the security light has never come on. It sounds as if I can hear the fuel pump priming when I turn the key to the on position. The VATS system could very well be screwing me over; I tried disabling the system in the rear and then turning the car on, but that was a no-go as well.
Old May 24, 2006 | 06:56 PM
  #40
Luna's Avatar
I'll be very interested to see whats wrong here, my money says you have no spark for whatever reason.
