Longtubes are on, but car won't start...
Only problem is that the car won't start. It will turn over, but for some reason it doesn't have spark. We checked the coil packs, starter, plugs, wires, crank sensor, and fuses. Nothing is out of place, wrong, cut, clamped, etc.
The only other thing we can think of is that the front 02s are not hooked up. The 02 sensors on my 2000 Z28 didn't need extensions, but this one does and I don't have them, so I didn't hook them up. The car doesn't need those to start, does it?
What else could be wrong from a simple LT installation?
I'll see if I can get some 02 extensions tomorrow from a local shop or Speed Inc.
I'd like to hear your car with the 2OTL with pacesetters.
When I get the 2OTL on it, I'll get some clips up.
Yea, I really didn't want to do it to mine, but I forgot to order extensions and I was just way too excited to wait for them.
Just make sure you tape them up good and don't let em sit on the headers and its no problem.
Also, do it one wire at a time since alot of them are the same color.
Did you by any remote chance hit the crank sensor??? I did and for the life of me my girls car would not start.
It did not even throw a code, I trouble shot the **** out of it about 3 hours worth
If its turning over and your sure your getting fuel and spark then I will check that sensor. If you moved the engine around like some people do when they install long tubes(ME) then it is remote chance its that
WTF is wrong with this car? Also, make sure the coil brackets are bolted to the valve covers as I BELIEVE that it how they ground themselves. You could also get one of those lights that you ground and stab a wire with ( Idunno what its called) to check the plug wires to make sure you are getting spark.
The fact that you are not getting any codes makes me think its something simple like fuel, power or spark.
How about the fuel lines? Just throwing ideas around.
