Longtubes are on, but car won't start...
Just not sure why.
QUOTE]
Does this work? I never heard of doing that. Ive always just measured the resistance in the resistor on the key. THen bought a resistor that ohm. Then found the two white wires under the dash cut them then spliced the resistor in between them to by pass VATS.
Told us everything we needed to know. The engine temp sensor (that I replaced yesterday) wasn't getting a good wire connection and was therefore telling the car that it was sitting at -38 degrees. A little wiggling and prying got it back up to air temperature at 77 degrees. So he's just going to play with the connection on that and see if he can't get the wires to hold better. Also, the crank sensor wasn't getting proper signal, so he's going to check the wiring on that as well and possibly just replace the sensor. Basically, everything that was a problem was something that we'd looked at or fixed, but just wouldn't be able to tell if it was properly working without the use of this tool. If everything problem-wise stays this minor, the car should be back up and running by this afternoon.
Thanks again for everyone's help!
I hope you get it fired up this afternoon! Good Luck man!
). He said he replaced those, tightened up the wiring on the Engine Temp sensor, and she fired right up. I owe that guy a ton.Time to go pick up the car and drive it around with my full exhaust!
That's Awesome!! I'd like to see what you think about the sound when you get it back. With my cutout closed, mine's actually very quiet.
(it was my 4th exhaust) until I stalled it. That took a lot of the rasp out because it wasn't seeing as much load under normal driving conditions.
I go through exhausts too.
