Throttle body differences
Old Jan 19, 2003 | 10:22 PM
Hitman#1's Avatar
Default Throttle body differences
Are there any differences in throttle bodies between years of LS1 F-Bodies?
Old Jan 20, 2003 | 09:02 AM
Paul F's Avatar
Default Re: Throttle body differences
98-99 are the same and 00-02 are the same. The linkage is the only difference between them.
Old Jan 20, 2003 | 10:43 PM
jimmyblue's Avatar
Moderator
Also differences in the coolant fittings
(early are same both sides, late are
fat, 90-degree on passenger and skinny,
straight on driver's side. And PCV breather
fitting was different on my '02 than the
early body I ported. PCV fitting is easy
to remove /swap, coolant is a bitch (can't
say impossible, but it felt more likely to
break than give, so I quit).
Casting #s are the same, it's just fittings
and shaft / spring that differ. If you're
going to bypass, then the rest of the
differences don't matter as everything else
will swap easily.
