Lid install problem....
Old May 26, 2006 | 01:20 PM
wraith051373's Avatar
Default Lid install problem....
98 WS6 TA
Yeah, I know this is supposed to be a 10 minute deal....
Ordered the MTI clear lid. It will not fit in the slots in back. The round part of the lid, and the bottom of the MAF are hitting the radiator cover housing/ bottom of airbox. Anyone else have this problem? I'd hate to cut that shroud and still find out that there is not enough room due to the radiator. Also, was I supposed to get a rubber sleeve or anything? I'm worried that when I tighten down on the supplied hose clamp that I am going to crack the lid. Finally, it doesn't seem to seal real well at the base of the MAF. Suggestions?
Old May 26, 2006 | 02:50 PM
A-Bomb's Avatar
did you order it from MTI?
Old May 26, 2006 | 03:02 PM
rgaynor85's Avatar
slp fits tight also u just gotto mush those tabs into there at whatever angle it go in at, once it goes in once or twice itll be easy from then on. the round part and maf is hitting cause you dont have those tabs in cause like u sid they dont fit, its supsed to be a tight fit underthere. there is no rubber hose the maf just pops in a always feels a little loose, just githen that clamp on the maf it wont break anything u can put everything u got into it with a screwdriver and it wont break.
Old May 26, 2006 | 03:14 PM
yup, ordered from MTI, just figuring I am doing something wrong, and wanted to make sure before I called them....
Old May 26, 2006 | 03:22 PM
00'WS6Rocket's Avatar
I had to use tie's to tie the front down cause it kept popping off
Old May 26, 2006 | 03:29 PM
00Pontiac's Avatar
yeah the MTI is a little tight on the first install... once you do it once or twice it fits much better... I called MTI and explained this to them, they said they are all like that and if it cracks they'll just send me another, so I stuck it it with no fear of cracking it and in it went... np now.
Old May 26, 2006 | 04:17 PM
A-Bomb's Avatar
i was gonna say exactly what 00Pontiac said.
Old May 26, 2006 | 04:36 PM
Yeah, I called, and got the same answer. Muscled her in, no problem now. I woulda put money on it cracking... Guess I'm used to aftermarket stuff for the NSX, which actually fits right the first time...
Thanks for the advice!
