To Merge or not to Merge, That is the Question...
I am really on the fence with this one!
Ryan K. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
<small>[ January 30, 2003, 08:45 PM: Message edited by: Ryan Karasek ]</small>
BTW. from the looks of it that new set up is gona be sweet. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Let me make my question more clear, Will using merge collectors at the header point not the Y.
Just to clear that up...
Ryan K.
How much power do you think the merged collectors will get you with your 414" motor?
Louis pointed you in the right direction here:
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=006138
If I was spending the dough on a big inch motor I wouldn't hold back. Do it once, do it right, and enjoy it. Of course, this is a better corner to cut than say scrimping in the bottom end.
Mike:
I am a cheap bastard and appreciate economy issues, but you are comparing apples to oranges. Whether the gain seen with a well designed merge collector over a standard collector is worth the added expense is a different question. The cost isn't a function of gains realized, it's a function of production costs which are most definitely higher.
I think that it's probably more involved than just bolting it up & go. You would have to experiment with going longer or shorter on the collector. This would shift the power throughout the powerband. You just need to experiment to find the optimum for your car. I'm sure there would be some benifit to just bolting it up, but to optimize it, you would have to do as I have described.
1 7/8" > 3" high flow merge collectors, which came at 268 a pop. in the end i figured it was all or none and spending that kind of money for my eventual built motor and to essentially suffocate it because i could not utilize the terminal pulsing/scavenging effect created by their higher velocity. i chumped it up and man they were sweet and worth it, just until i could not take the continual leaks between the collectors and the primaries. now the QTPs take their proud place and run into a mufflex 3" y-pipe to a 3.5" I-pipe into the borla.
Have you considered contacting Burns regarding the merge collectors, etc? They should be able to design you a nice system.
Burns Stainless X-Design
Joe
<strong> Ryan,
Joe </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">One of my buddies is a Burns dealer, you can expect to pay OVER $300 for each collector. Not bad for a handful of horsepower huh?
