mac header install?
Old Feb 2, 2003 | 02:17 AM
cameroz282k's Avatar
Default mac header install?
can any one point me in the right direction on how to install my mac headers on my 00 z28 i will be greatful of all replys <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 2, 2003 | 03:41 AM
akaceril's Avatar
Default Re: mac header install?
try a search. both on this board and on the web. that is how I got mine done
Old Feb 2, 2003 | 03:14 PM
ttt <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Feb 2, 2003 | 03:43 PM
TATERBUG01's Avatar
Did mine this weekend solo. Valve cover and coilpacks on the passenger side - header thru the top. Oil filter removed and casting block cut off - header thru the bottom on the driver's side. Patience and take your time!!!! Mine is an 2002, no EGR made it a tad bit easier.
Old Feb 2, 2003 | 04:20 PM
slick98ta's Avatar
Both through the top with valve covers and coil packs removed.Took about 4 hours.
Old Feb 2, 2003 | 04:34 PM
destroyerSS's Avatar
are you doing this swap on jackstands or a lift? and are u going ory or cats
Old Feb 2, 2003 | 11:27 PM
off road y on jackstands also do i need to buy o2 wires that r longer if so cant do it till next week so please tell me i dont <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Feb 2, 2003 | 11:52 PM
N2Ofreak's Avatar
Go to install university. I have the macs and love them!I have the install info on my laptop but do not know how to post it.It will take about 8 hours since i guess its your first time installing these headers. You have to remove the coil packs and valve covers,You also have to jack up the motor unless you can grind the block on the passenger side. drivers side is easy!
The install is not to bad just time consuming.You should change your plugs while doing this install,which i'm sure you've been told!I also got new manifold gaskets from the dealer,I know you can reuse the old gaskets ,but I think this is why guys have problems with bolts working loose!
Old Feb 3, 2003 | 10:42 PM
RaNsOm's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by N2Ofreak:
<strong> Go to install university. I have the macs and love them!I have the install info on my laptop but do not know how to post it.It will take about 8 hours since i guess its your first time installing these headers. You have to remove the coil packs and valve covers,You also have to jack up the motor unless you can grind the block on the passenger side. drivers side is easy!
The install is not to bad just time consuming.You should change your plugs while doing this install,which i'm sure you've been told!I also got new manifold gaskets from the dealer,I know you can reuse the old gaskets ,but I think this is why guys have problems with bolts working loose! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">jack the motor up? are you kidding me?? damn...well im putting my MAC's on this weekend, through the top with the coil packs and valve covers off....letcha know how it goes. I'll have 4 people workin with me with full access to every tool, impact tools, and a lift. should be easy
