MAP sensor problem
Old Jun 1, 2006 | 02:13 PM
CRZYPWR's Avatar
Default MAP sensor problem
Ok. So I had the car tuned. They were not able to tune it %100 because my MAP sensor would not work. They put another one one... still same thing. MAP sensor was not detected. What could be the problem ?
Old Jun 1, 2006 | 02:46 PM
jimmyblue's Avatar
Moderator
Seems to me like you would have substantial drivability
problems with a malfunctioning MAP sensor. So this
smells funny to me.
Old Jun 1, 2006 | 02:53 PM
LoudmouthLT1's Avatar
If you have tried a new sensor and it does not work first thing to do is check for a power and ground to the sensor.
Old Jun 1, 2006 | 02:54 PM
BadAzz96Z28's Avatar
My car keeps throwing a MAP sensor code also...not sure what it means...says MAP Range/Perf....any insight on this jimmyblue? I have seen different tuners cutting off he MAP code when tuning but I dont know what that will do If I did that.
Old Jun 1, 2006 | 05:18 PM
CRZYPWR's Avatar
How about if power and ground is fine and sensor still will not work ?
