Who has Grots & SFC's?
If I replace the engine mounts with poly, I presume the exhaust will shake significantly less. Assuming no other issues as a result, would you put on SFC's first and have a custom y-pipe fabbed around it, or vice-versa? Which SFC's?
You can have a Y-Pipe fabbed up any time. Now, if you're running a cutout you may want to see how close your cutout comes to the rear most portion of the front frame. That will give you an idea if you need to do the SFC's or Y first.
On the G2 brace I don't even think the pipes will come that close. I'd call up Lou and ask him what he thinks.
<img src="http://www.lgmotorsports.com/pictures/products/g2-sub-vbrace-loop-lg.gif" alt=" - " />
