Motor mounts = pain in the butt IF
I did the passenger motor mount a few months ago and it helped with some banging issues. Since I had a holiday (last weekend) I decided to take some time and do the drivers side. How long did it take me? Don't ask I am too ashamed to tell.
BUT what a wonderful difference it has made!! Less in-car vibration and no more chattering from the Spec Stg3 clutch!! Why didn't I do this earlier = ignorance.
Please learn from my mistake and do the freakin motor mounts when you do headers. Now I love my car even more. Next up : torque arm.
Thanks Tom (Squirrelmaster) for lending a hand. You're a good man.
Brian
https://ls1tech.com/forums/generation-iii-external-engine/492703-best-poly-motor-mount-write-up-ever-written.html
I think Thunder Racing needs to send me about a $500 check because I KNOW I've told about 10,000 people to do poly motor mounts, and that's the only place I could think of that sells them.
BTW - Do a poly trans mount and your shifter will be dead still as well if you have an M6. It really helped my wheel hop problems also.
The results are incredible. You should definitely do them but do them both at the same time so you can lift the engine up higher than I was able to. I think that part of my problem. The hardest part for me was getting the four bolts back into the block. They just wouldn't line up. I had 3 out of 4 bolts in but the last one was just a little off...I was sooo pissed. I considered taking the mount back out to just drill the holes in the mount a little bigger to give me more leeway (sp?).
Also you want to have some Craftsman ratcheting wrenches at your disposal
The passengers side is not nearly as bad though.
.And we definately need to thank my ratcheting wrenches, we'd have been screwed without them
.Oh, and you certainly impressed my brother with the joy ride, and you definately pissed off my neighbors with your exhaust
.Tom
.Tom
LS1
I was in the same boat as you when I did my headers. I was just too lazy at the time.
How much of a PITA is it after headers have been installed?
