Loud Whining On Warm Start
Also I'll be pulling my valve covers soon to check my pushrods (almost positive I have 1-2 bent). Just pull the coilpacks, valvecovers, unbolt rockers and pull them out?
Thanks for the help
search for "air pump removal"
You're correct on pulling the stuff apart. Put the rockers back on and torque to 22ft-lbs, rotate crank over a bit and re-check.
haha the simplest ideas are the best.... The Best V8 Stories One Small Block at Time
Hey, I had the same problem. Every now and then upon cold start up it would whine and after a hot minute it would quit. Sometimes it would even happen while I was driving and came to a stop. IT DROVE ME NUTS!!! Moved on to installin LT's so at the same time I took out the A.I.R pump and never had this problem again. When it happened it almost sounded like my power steering was going bad, but turned out it was that stupid pump. Good luck!
P.S if the whining sound goes away when you slightly hit the throttle then you have the same problem I had to the point!!
