white tip spark plugs?
What does that mean if anything?
Thanks,
Greg
you dont want them to black because then you are pig rich <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
but the other side should be the same though. You may have a bad 02 sensor. When my 02 one the drivers side went those plugs got very black and fouled on that side
<strong> We were doing a LT header install, and when we pulled the plugs the tips where white. This was only on the drivers side, the passagner side was fine.
Best thing to do is AutoTap/LS1 Edit. and see why it's running lean on one side. No matter what your Mods, you want to run the same Air/Fuel Mixture on all cylinders. A 'visual' plug reading is not always accurate. You may have before or after Cat issues if your running them.
Thanks,
Greg </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> .... <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
heavy crystalline / grainy white deposit
can be coolant. If one, or two adjacent
plugs are unusually crusted up this can
be a sign of a head gasket coolant leak
or a cracked head. If you see something
like the latter description then do some
more looking for confirming cooling system
symptoms.
<strong> A little white or tan film is not bad. A
symptoms. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">well that low radiadior coolant light,(not the "low coolant")the little box with the arrow pointing down come on fromtime to time. I check it everytime and its always full. I dunno if that has anything to do with it or not, just putting out info.
