Header bolts......
Old Jul 15, 2006 | 11:08 PM
BobbyWS6's Avatar
Sometimes you just got to say what the F*&k! Use the washers and take it easy. Do you have a good stock bolt or bolts? You can just run it in and out many times and blow it out damaged threads shavings with WD40. (in short burst with red straw) Use all the good bolts that you have. If one gets a little damaged, move on to the next stock or extra bolt. Then, when you feel you have enough threads to hold it in place blow out hole with contact cleaner/break cleaner (using red straw from WD40 can) and thread it up with locktight and your washers. Just make sure the washers are the correct ones. Dont get sloppy here because you are almost done! Good Luck, take your time.
