pacesetters and tsp ory
Old Jun 11, 2006 | 03:42 AM
z28_n_tx's Avatar
Default pacesetters and tsp ory
im having fitment issues...is the header suppose to go over the ory ?? the drivers side seems to fit fine(header over ory), but the passenger side doesnt fit at all. do i need to abng on it a bit to make it fit??
Old Jun 11, 2006 | 12:03 PM
z28_n_tx's Avatar
Default post pics of your pacesseters and tsp ory on a car
just like it says..thanks
Old Jun 11, 2006 | 02:48 PM
TheBlurLS1's Avatar
That's what she said...
The header should slip inside the y-pipe.
Post some pictures of it, it would really help.
Old Jun 11, 2006 | 02:52 PM
2K2WS6TA's Avatar
I know on my pacesetter y I had to open up the y pipe hole so the header collector would slip in, a little tweaking with some vice grips was all it took
A tip for anyone else reading this, test fit the pieces together before trying to put them on the car, it's alot easier to adjust/tweak stuff when it's on the living room floor, than half bolted to the car
Old Jun 11, 2006 | 02:53 PM
TheBlurLS1's Avatar
PS - Why don't you do a search instead of making 2 threads about the same thing? The more threads that get posted, the less they will be looked at.
Old Jun 11, 2006 | 06:12 PM
Shallow Bay's Avatar
Bring it to an exhaust shop and have them expand the pipe a little.
Old Jun 11, 2006 | 06:37 PM
z28_n_tx's Avatar
i did a search with no luck..ill post some pics when i get back home thanks though
Old Jun 11, 2006 | 06:59 PM
TexasVortexx's Avatar
If it's the TSP catted Y I would like to know about the clearance once you get it all on and driven some.
TIA
UPDATE: I jst read the threat title ORY, sorry
Old Jun 11, 2006 | 09:38 PM
ninetres's Avatar
Y goes over the header
Old Jun 11, 2006 | 11:39 PM
2002ssls1's Avatar
When I installed my pacesetter long tubes and tsp ory I had to take the 2 pieces of thr ory to an exhaust shop and have them expand them a little. To expand the pipe, it takes less than 1 minute per piece. You will also have to modify the piece that goes under the tunnel brace or it will hit when you leave from a stop. Another thing you will have to modify is the piece that goes under the transmission that connects the driverside to the passenger side(not sure what it is called)
Old Jun 12, 2006 | 12:01 AM
ninetres's Avatar
You mean "might" have to modify. Mine installed in minutes with some good old fashion elbow grease. The only modifying I did to eliminate the knowcking was shave a little material off of the trans brace (t56).
