true duals piping question
It will work but will require some cutting and welding. You will need to buy 1 mandrel U bend extra. Some of the pipe that you trim off the rear section can be used as an extension to reach the headers.
Dan
The passenger header exits straight back so you just use the 45* in the kit. It will come up short of the header but you can use a piece that you cut off the rear section to extend it to the header.
The driver side when it comes out of the x you need more angle than the 45* in the kit to swing out around the xmember and also to make a sharp bend back to the header which points outward.
The driver side totally takes all the fun out of making the duals from the universal kit. An LT1 car is easy.
I assume it will flow more with duals than the cutout, but should I go with 2.5 or 3 inch? I'm going to be running nitrous soon.
