turned the car on after LT's install and...
FYI the temp sensor is located right in front of the header flange on the #1 cyl drivers side, make sure you haven't damaged the wires, connector, or sensor itself, you may have hit it while installing the drivers side header, or it may not be plugged in all the way.
As for the loudness, what catback do you have, and also remember the sound is no longer under your feet, it's out the back, so it'll sound quieter to you, let someone drive your car, and you stand by it while they accellerate away, it'll be loud
damn smoke wont stop coming out..i got under the car earlier and i noticed that there's something on the header, which i believe is causing the smoke ..but i dont see where its coming from.
BTW you know your temp gauge is a dummy, right? the only way to tell the temp of the engine is an aftermarket gauge, or software like EFI Live/HPTuners
this has become such a head ache....i regret putting my lt's now
here are some pics....i dont think its broken..what do yall think??
It should be easier to get in if you can have a friend up top, to push/hold it while you guide it in the hole, tho it's possible to do it by yourself, it just takes a little longer
now i only have to change the temp sensor...i keep getting the P0118 code,eventhough my SES ligh has not come on for a couple of days now. stupid Q but ill ask...its ok to drive the car right????untill i cahnge the sensor at least.
So I reset the PCM correctly. Ignition on , car NOT started, pull the PCM IGN and PCM BATT fuse for like 15 mins. Key off, put em back in, start it up, and my code was gone, hope that does it for you. Note: I dont think there is anything wrong with your temp sensor and I would try this before you attempt to change it.
Also that smoke you were seeing was probably blowby (I think thats what its called?) from the dipstick tube hole, make sure you put the bolt back in too so you arent ordering a new dipstick tube anytime soon.
no, its not a typo it did idle for a bit at 4000-5000, first start up. it also sounded like it was goign to go dead. but its now back at 6000 rpm's. doesnt sound like its going dead either. but i have not driven the car either.
anyway, glad you got it fixed. and the statement you made about regreting buying headers, you'll take it back.
